Discrete Opamp Open Design - Page 199 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 4th November 2012, 09:57 PM   #1981
Originally Posted by hitsware View Post
Thanks for this hitsware. So Ro = 1/hoe
A quick experiment measuring 1, 2, and 3 matched diodes in parallel gives about 35 Ohms series R so they behave "ideally" only up to 10's of uA.
So my crude estimate of 20R for 1n4148 is in the ballpark and so is the 'cure' .. tweaking the simple current mirror resistors.
_______________________________
I propose to yus gurus SPICEing that we also do a more stringent load test
3.162Vp 20kHz into 15R. OPA configured as Voltage follower
This is from NwAvGuy: O2 Headphone Amp
I'm having difficulty getting the various contenders to show THD above -140dB on a 600R load which implies no sensible real life results with a 24b soundcard. It will also show up important 'CMR' effects.
It's already showing up some of the BJT models at high currents.
BTW, IMHO, even with seriously PITA matching, I think we will need tweak pots for offset and maybe for Iq. The first guys who build a breadboard get to pontificate on this.
Old 5th November 2012, 02:53 PM   #1982
scott wurcer's Avatar
Of course you will need to trim or select resistors if you want really low offset. We also went over the output current thing before, if you want a 32 Ohm headphone amp it will be different.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 5th November 2012, 03:08 PM   #1983
aparatusonitus's Avatar
Scott, I'm really interested what you think about my little baby?
Non mai abbastanza...
Old 5th November 2012, 03:19 PM   #1984
Regarding the follower stage of the open OPA, There are some Sanyo BJT's available in SOT89 (Sanyo PCP) package that are supposedly compliments (although not very well matched) 2SA2125 2SC5964. Data sheet doesn't specify use for linear applications but the transfer function looks pretty good in the range it will be used (<300mA) and they have a fairly good fT ~ 380mHz and a good max dissipation for SOT89.
Would there be any performance advantage in using these when compared to say the BCP53/56 compliments?
Old 5th November 2012, 04:48 PM   #1985
myhrrhleine's Avatar
If you need a low impedance load then maybe you should consider the FET output stage used by Mr Cordell.
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 5th November 2012, 05:25 PM   #1986
At first glance this looks fine.
Old 5th November 2012, 05:28 PM   #1987
I'm sure they would work in the circuits we are discussing. Pesky holes and electrons!
Old 5th November 2012, 06:54 PM   #1988
Thank you Scoot...btw, Sansui-Rush opamp can/could be converted into a Rush-Rush opamp in a sec with similar DC/AC performance.
Old 5th November 2012, 08:56 PM   #1989
Sonitus, will you oblige us with your LTspice file so us wannabe SPICE gurus can have a play? Also your Rush-Rush version?
On 2nd thoughts, 210mA peak may be a bit too stringent. c2240/a970 & bc556/546 are only 100mA. 4401/3 are OK but I was trying to get a series of tests for the contenders which didn't need too many special devices in special places. Special i/ps are unavoidable.
Got a link or sketch of Cordell's output stage accessible to beach bums?
Low loads aren't a problem if you are prepared to use medium power devices like the original 990 or even just 4401/3.
Scott, did you get your breadboard up & running?
My contention about offsets is that you may need tweak pots to avoid Volts of offset rather than mVs even with loadsa device matching. But this is just from SPICE so the breadboard man has the last (??) say.
Old 5th November 2012, 09:45 PM   #1990
PHEONIX is offline PHEONIX  Australia
Hello kgrlee,
What is your desired ultimate spec THD into 15R @ 20KHz @ 3.162Vp that you seek to attain.
Arthur
Discrete OPAMP audio-gd Vendor's Bazaar 28 12th May 2015 06:32 PM
discrete opamp help blackpowderaudio Parts 0 16th December 2009 03:46 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Copyright 1999-2017 diyAudio
