| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#1451 |
That's better, interesting. I think you are missing a couple of diodes on the right side of the input stage, this might saturate the cascode.
Clay is embedded in our subconscious. It has been there for at least 50,000 years. |
#1452 |
Loop Gain.
#1453 |
#1454 |
Would you be kindly enough to post your LT Spice files ?
Then we can all play with it. Many thanks in advance, Patrick
xen-audio.com |
#1455 |
If you meant me here it is.
#1456 |
is choosing a less facetious title...
ha, sorry for the laziness, autocomplete gives me that as I use it more often I guess and I havent trained myself to correct it. it also isnt set in my brain to use complement as a singular noun (by itself), or complementary as a noun at all… I know its correct, it just isnt habit. it seems to get used as a technical adjective, noun, or pronoun interchangeably.
#1457 |
pronoun? lol..noanyway back on topic, I can see another model of custom jfet SMD heatsink coming on. I guess I better break out the matching rig and go through my j103/k246. would these compound mosfet networks be of any use here? i've been thinking about getting some to play with for a while. fairly low voltage though Last edited by qusp; 2nd October 2012 at 09:44 PM. |
#1458 | |
I can see a signal path through Q15 on some of the later 'symmetrical' versions but not on the simple ( ) #1380 circuit.Or are there some missing tracks on #1380 ricardo |
#1459 |
Excuse, my ignorance but az i kunt reed en rite, I'm only on page 97 in my journey through these guru postings.
I get the impression this is a competition to be judged against Guru Wurcer's offering via LTSpice From his #1380 post, the constraints are - -100dB for 2nd, 3rd etc @ 20kHz with 20dB gain into 600R - 2nV/rtHz noise - zillion V/us into 10n - 50R headphones too. Please correct me if I'm wrong. I'd like to enter with my offering using NOS Mullard EF37As. |
#1460 |
Many thanks to dadod for posting his version, I'm having problems with the output operating point, which is varying all over the show, up to nearly a volt offset. I need to play around with the models a bit more to get a handle on things ...
Frank |
| Discrete OPAMP | audio-gd | Vendor's Bazaar | 27 | 20th September 2012 04:02 PM |
| discrete opamp help | blackpowderaudio | Parts | 0 | 16th December 2009 03:46 PM |
| THAT transistor headphone amp (250ma discrete opamp) design sanity check. | Russ White | Headphone Systems | 19 | 13th December 2007 12:52 PM |
