| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#51 | |
diyAudio Chief Moderator
#52 |
That's very nice, but if you screw up the signal source trying to drive the low impedance, you're not exactly ahead of the game. You might try increasing the bias current in the mosfet. That definitely worked for me in terms of reducing the distortion. I'm biasing the input jfet at ~5 ma, which should work nice for the 2SK117.
#53 |
Here's the latest effort - a bit neater that my first. There's two channels and an onboard shunt regulator. The output mosfet and its current source drain load are both cascoded. One channel exhibited high amplitude oscillations at ~350 kHZ (so low?), while the other looked stable. About 3" of "gimmick" capacitor was applied to the feedback resistor of both channels. It stopped the oscillation on the one channel, and did not obviously destabilize the other. Next up are tests to determine what is going on. I'll post schematics when I'm reasonably satisfied.
#54 |
Nice board wrenchone.
Waiting your final schematic. I did try salas suggestion with lower resistors. Noise was down but distortion was higher. With less sensitive speakers maybe there is no problem.
"Without deviations from the norm, progress is not possible" - Frank Zappa |
#55 |
Hi Wrench,
here is my take on "turning a (MOS)FET into a SIT/triode". Fair Zin, low Zout, BW(-3dB)=1MHz, rail-to-rail swing (almost), high PSRR, Id about 15mA, sounds wonderfull - what more could a man want ? ![]() Built, tested, measured (except for THD) - here is the schematics: |
#56 |
Juma,
R2-4, D1, and C1 are biasing network for top fet? Also, are ther two feedback loops R5/R7(schade component) and R6/R7? Very interesting thread from Wrenchone. Love following it.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#57 |
Yes, it's called a gyrator (fake choke - the most appropriate load for the fake triode
). Voltage divider R2/R4 sets the gate of Q1 at about 2.5V above Vcc/2Right. It sets the gain and Zin No. Voltage divider R5/R6 sets the Id. R5 is already involved in gain setting so the R6 is the one to be manipulated to set the Id (I find the 15mA to be an optimum value) |
#58 |
As always, Juma, a clear and easy to understand explanation. I don't know why less thinking R5/R6 was feedback, didn't click that these were enhancement mode devices and needed a positive voltage at the gate. I think I have seen the gyrator, minus the diode and with cap going from divider to ground, used to bias the top Jfet in an SRPP type circuit. I have been watching this thread as I am considering trying to use LU Jfet in FE for BA output stage and wrenchone always interesting circuits if for no other reason than just learning. Thanks to both of you.
#59 |
Don't look now, but I've got another version of this thing up my sleeve. PSpice and the other simulators are wonderful toys (to geeks, at least).
#60 |
Hi Vgeorge. Having a suspicion also about the CCS amplifying its degeneration resistor's noise enough for your high sens horn speakers, I looked in to just a resistor current source. So I brought back your input impedance higher for your source and pot to better handle, hoping that if there was hiss contribution by the CCS maybe we can trade what we last time cut by lowering Rf/Ri. If you still got it handy its an easy mod to test. Sims >30mA for M1 and a bit more THD 2ndH in the mix. R7 should be a 2W part.
| L'Amp: A simple SIT Amp | ra7 | Pass Labs | 1686 | Today 04:21 AM |
| SIT Amp Article Out Now | Variac | Site Announcements | 0 | 2nd December 2011 07:55 AM |
| SIT-Preamp | VladimirK | Solid State | 36 | 27th August 2011 08:36 PM |
| SIT Power Amplifier??? | mad_z | Solid State | 8 | 26th January 2009 08:31 PM |
| New SIT - old problem | StevenOH | Parts | 2 | 13th June 2008 10:46 AM |
