Go Back   Home > Forums > Source & Line > Analog Line Level
Old 7th February 2012, 03:04 AM   #1
Default cs3318 and arduino
I'm starting my journey on the new (to me) cs3318 8-channel analog volume control chip.
for the last 2 years or so, I have been using singles and pairs of pga23xx chips and now I'm going to give the cirrus 8ch chip a try.
today, I soldered that expensive chip onto a schmartboard:
and since this chip is 3.3v based and my arduino is native-5v based, I'll need i2c level conversion:
I'm using my Volu-Master code base (newer version of what is on AMB.org's website for the LCDuino and alpha10 preamp). since the cirrus chip works very similarly to the pga, it should be a few lines of code change to at least be able to control the master1 fader group (in theory..)
will continue as progress is made...
My Photostream:http://www.flickr.com/photos/linux-works/
Old 7th February 2012, 07:25 AM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
I'm using a CS3318 in my DCX2496 output mod. So if needed I can probably answer questions on driving it when they come up.
At the time I was stilll programming in assembly so the code is probably not very usefull.
Are you aware of the dummy register writes you have to do to overcome a firmware error? Don't know if it has been solved in the chip at the moment but I still do it.
jan didden
/Another new issue: Linear Audio Volume 3!
Old 7th February 2012, 08:15 AM   #3
Turbon is offline Turbon  Sweden
Turbon's Avatar
jan didden
Jan, why would assembly be a bad choice and unusable today?
Brgds
These are my principles, and if you don't like them... well, I have others.
Old 7th February 2012, 10:28 AM   #4
I am also interested in it, however to avoid complexity i will be driving it with PIC24 series PIC , which is 3.3v driven.
Probably will need many help related to this . i am new in the digital control .
Old 7th February 2012, 11:12 AM   #5
janneman's Avatar
Brgds
No it's not a bad choice at all, it's just that for occasional use (not using it on a daily basis) it's not easy to maintain your proficiency.
I now do all my programming on PICs using Flowcode, which is a graphical programming interface on top of C. Works great and has a very shallow learning curve, which is great for occasional use.
jan
Old 7th February 2012, 02:29 PM   #6
ds23man is offline ds23man  Netherlands
jan didden
http://www.digikey.com/Web%20Export/...f?redirected=1
Regards Gerhard
Old 7th February 2012, 02:50 PM   #7
jan didden
have not gotton that far yet. can you give more detail on that issue? does the chip lock up somehow or is this the method they describe known as 'aborted writes' in order to execute a read command?
I'm not even sure I need to do reads. why do you need to read anything? the whole chip is write-oriented and seems like you can fully control it via write-only CSRs.
Old 7th February 2012, 02:53 PM   #8
Brgds
my take is that its too much work and the compilers are so good at optimizing, its rarely needed to do assembler anymore.
for high speed things, sometimes it makes sense; but for example, the arduino code that actually follows the 38k IR signal, bit by bit, is a pure C code software routine. no hardware help was needed other than setting a hardware timer inside.
my whole last project was about 12,000 lines of C code. no way would I ever consider doing that much end coding in assembler! I shudder to think of how many assembler lines that would have been!
Old 7th February 2012, 02:57 PM   #9
Originally Posted by ds23man View Post
aha! so that's what the issue was.
I did not notice this until you pointed it out
I went all up and down the main data sheet but I guess cirrus did not think it was 'worth the effort' to updat their MAIN data sheet. wow.
thanks!
Old 7th February 2012, 02:58 PM   #10
If I read the errata correct it is neccessary to write these once after startup for achieving max. audio performance. Nothing to do with reading.
Regards Gerhard
PS Why is this not in the Datasheet???????
Digital Volume Contol - CS3318 - MAX5440 Ridin '24'z Digital Source 5 8th June 2011 01:36 PM
Sylonex and Arduino preamp oenboek Analog Line Level 17 12th March 2011 12:50 AM
Arduino for audio projects? glt Parts 5 9th March 2011 05:28 PM
Cooling fans with Arduino seahuston Chip Amps 10 23rd October 2010 05:58 AM
Can DIY audio be like Arduino glt Everything Else 1 3rd April 2009 03:57 PM
Page generated in 0.12388 seconds (80.17% PHP - 19.83% MySQL) with 11 queries
