| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I am starting a new thread about this circuit board, which I initially posted about in another thread on some modular active crossover PCBs that I am also developing.
As a speaker building hobbyist, I have wanted to have a flexible circuit board that I could use to build a variety of filter types. Since I didn't find anything available, I decided to design and build my own. It has been invaluable to discuss the designs and the capabilities here, so I am inviting people to join in. Hopefully I will end up with something that many people could find useful, too. I call this the "Universal Filter Board" because you can use it to implement pretty much any type of filter that you would want to use for loudspeaker crossovers. These include:
The circuit uses a single dual op-amp and there are two independent sections on the board, each using one of the amplifier's in the IC. Each PS rail is decoupled to ground at the IC pin and there is a rail-to-rail decoupling cap as well if you would rather decouple that way. Inputs are via miniature screw terminal blocks or you can solder wires directly to the signal I/O and PS pins. I have built and tested a prototype of this board that has slightly different functionality, and the performance was pretty good. This latest revision adds the jumpers, rail-to-rail bypassing cap, and expands the range of functional capabilities. After some more review of the PCB design, I plan to get a few prototypes made to test out this revision of the design. I will post more info when I have it. -Charlie |
#2 |
Weirdly enough active filters don't get attetion/support here
All-in-all they are superior, easier to play with, and give much more versatility than passive filters. And they are cheaper even with good performing amplifiers on their outputs. Maybe that's besause of "voodoo" of analog low-signal active circuits where you have to design (calculate) them yourself? Probably "many opamps" thing is the main turn-off... |
#3 |
Well i have to take my words back, as i've somehow overlooked your previous threads
They have some interesting discussions, i'm studying them right now Too bad i'm doing this after i finished my crossover board By the way, it seems you have lots of experience in active filters - have you ever compared the performance of different filter topologies, i.e. MFB/SK/State Variable/substractive? |
#4 |
this sounds excellent! might i suggest multi-stage buffering? a JFET buffer followed by an op-amp buffer can work wonders. check out this link for some useful tidbits AMZ Basic Buffers
#5 | |
I am currently doing some modeling of the biquad circuit to make sure that you can implement the Linkwitz Transform using the Friend SAB circuit. I am also trying to incorporate the sensitivity of the circuit(s) to component tolerance in a design spreadsheet for each topology. I did the with SL's LT circuit recently, by implementing something like Monte Carlo analysis in Excel. After making these last design changes, I have definitely been able to simplify the PCB layout since the last iteration. This freed up the room to add the rail-to-rail bypass cap, and to allow for a lot more breathing room near the edge of the PCB. This might just become my go to PCB for crossover design because of its flexibility. For high Q HP/LP stages and notches, I may instead use a PCB based on a SVF biquad (my modular filter board), since the circuit less sensitive to component variations and can handle high Qs without a problem. -Charlie |
#6 | |
-Charlie |
#7 |
Today I managed to figure out how to use the "Friend's biquad" circuit to implement a biquadratic filter function, e.g. to use it as a "Linkwitz Transform". Since this is one of the circuit topologies that my "Universal Filter Board" can take on, this makes the PCB super flexible because I was expecting to have to design yet another PCB for the LT circuit but now it looks like I can just use the UFB! Awesome.
In the next couple of days I hope to do some Monte Carlo type analysis of the circuit sensitivity. Since there are several adjustable parameters in the design of Friend's circuit, I need to see how to minimize the response deviation. I also want to see how sensitive the response is to resistor and capacitor tolerances. Anyway, that's today's update. So far so good! -Charlie |
#8 |
After a few hours of plugging away at it, I completed my sensitivity analysis for the Friend's biquad circuit. This included calculating the exact component values required, then looking up the nearest "real world" component value (e.g. the E96 or E192 series resistor value), and then doing a sampling process to get a trial value within +/- % tolerance of the "real world" component value. This is the best way that I can come up with, using Excel, to model what happens when you build the circuit using real resistors, that can only be purchased in discrete values, and which have some range of values around that discrete value as described by the tolerance of the resistance value.
To get an assessment of the sensitivity of the response to these "real world" trial component values, 1000 calculations of the same transfer function are performed, and the min and max deviation from the predicted response for the discrete component value with zero tolerance are determined. This allows me to create a kind of "confidence band" of expected responses. What I found was that I could get the response to be within about +/-0.5 dB of the target, and the level of deviation was often less. To get this level of performance, I did need to use E192, 0.1% tolerance resistors and 1% capacitors, however these are readily available and not really all that expensive. The circuit is very flexible about the capacitor value chosen, since you can just do impedance scaling of all the resistors, So, bottom line is that I can pretty much do anything I need with the Friend biquad circuit. It's just like Sigfried Linkwitz's "Linkwitz Transform" circuit, except it uses one less capacitor (two versus three for SL's circuit). Both are single op amp biquads. Down the road I would like to do this same sensitivity analysis of this circuit, targeted for high-pass notch and low-pass notch circuit, which are used to construct elliptic filters. The noteworthy thing about the Friend circuit, and what some might consider a drawback (but I don't), is that it can not generate a response that has any gain at all, for any frequency. For example, this means that, a circuit that boosts the low frequencies for a subwoofer to extend the passband, the Friend circuit is cutting the higher frequencies. In constrast SL's LT biquad will boost the lower frequencies. In either case, the circuit shape remains the same, but it's something to keep in mind with the Friend circuit. Next up: modeling Steffen's second order All-Pass filter (unity gain). -Charlie |
#9 |
Today I figured out the design for the second order all pass (delay) filter based on the circuit of Steffen. This circuit has the main advantage that it has 0dB of gain or loss for all frequencies, regardless of the delay. This overcomes a major issue with some other all-pass circuit topologies, that can have 10dB or more of loss, and so have to be followed with a big gain stage.
The circuit design is actually pretty simple, once you figure it out. There are only seven components and an op amp. The circuit can be built on my Universal Filter board. I've been looking for something like this for analog delay for awhile. The other option that I have been considering is using an Antoniou biquad as an all-pass filter. This has a gain of 2 V/V but that is no big deal and can be paired with a 1:1 voltage divider at the input to restore unity gain overall. Speaking of the Antoniou biquad, I ran across some discussion of using a generalized form of the 2 op-amp version of this circuit to create LP, HP, BP, notch and AP, depending on how you configure it. I realized that with one or two tweaks I can build this topology on my First Order Building Block circuit board, so I hope I can figure out how to modify that circuit's PCB layout to accommodate the additional components. That would give me multiple options for each filter type. The whole goal of this experiment in circuit board planning is to make up a small number of boards that can be built up in to whatever type of block might be needed for loudspeaker crossovers, which is my main interest (active loudspeakers). So far, it looks like these two boards might be all I will ever need. -Charlie |
#10 |
I decided to do a "quickie" sensitivity analysis on the Steffen circuit without going through the hassle of creating a slow spreadsheet that runs 1000 random trials. After all, this is a pretty straight forward circuit. What I found was pretty encouraging.
With 1% resistors and capacitors, I can keep the amplitude flat within about +/-0.2 dB and the delay only varies by about +/-1%. If I change the resistors to 0.1% tolerance, the amplitude variation drops to about +/-0.05 dB and the delay variation drops to about +/-0.15 %. Interestingly enough, the capacitance tolerance has much less effect than the resistor tolerance. If I use 0.1% resistors but 5% caps, the variation is only +/-0.05 dB in amplitude and +/- 0.15% for the delay, so it looks like the resistors control all the variation and the caps are not much of a factor. Weird. Anyway, this looks like a very reliable and workable circuit for implementing a second order analog delay stage. I'm not sure why it isn't more commonly used. -Charlie |
| Active filter board GB | BobEllis | Solid State | 0 | 21st February 2006 09:30 PM |
| Page generated in 0.16428 seconds (74.69% PHP - 25.31% MySQL) with 11 queries |
