| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#2161 |
dtes,
how do you measure the internal temperature of a transformer? How do you know if your duty overheats the transformer? What does the transformer manufacturer tell you about drawing AC current from the transformer? What does the transformer manufacturer tell you about drawing DC current from the transformer? It appears you are completely ignoring what the manufacturer tells you about his own product. |
#2162 | ||
with a help of infra-red gun it shows about 50-55c on the surface in non ventilated enclosure.
Don't know that actually. The set of IC + Salas reg that I'm feeding requires about 80% of current that is written on the transformer. Quote:
![]() Anyway, I've got your point regarding toroid! Cheers |
#2163 |
and the internal temperature is?
max continuous AC current = VA / Vac when feeding a resistor. Max continuous DC current = VA / Vac / 1.414 * de-rating factor when feeding a capacitor input filter through a bridge rectifier. The manufacturer will tell you the de=rating factor for that transformer. Expect it to be ~0.7 This results in a max continuous DC current of ~ half the max AC current. You must check the manufacturer's data on how to use their product. |
#2164 |
#2165 |
The internal temperature could be at the maximum limit determined by the manufacturer, or below that reliable limit, or worse above that reliable limit.
You have no way of estimating the internal temperature by monitoring the surface temperature. |
#2166 | |
#2167 | |
That is not what post2157 said.
That means you would have 64/65ths of the current throughput of the Salas Reg for "hot-rodding". Whereas a 80mA DCB1 would have only 3/4 of the throughput as regulator overhead. That is a mighty big leap into "hot-rodding" territory. Particularly when one considers that 200mA and 600mA are both "hot-rodding" options. Last edited by AndrewT; 24th August 2012 at 03:42 PM. |
#2168 |
Thank you!
#2169 |
Andrew, I have a 100VA 15+15, what is the max I could safley run the DCB1 at?
#2170 |
mjock3
1.6A it is I suppose if to recapitulate Andrew's suggestion in post 2163. btw, what settings do you have now? |
| dcb1 buffer with shunt reg. | merlin2069er | Swap Meet | 0 | 3rd August 2010 05:25 PM |
| F2 and DCB1 parts selection - please advice! | DQ | Pass Labs | 6 | 25th November 2009 03:20 PM |
| Y B Blue - how blue LED improves the CD playback | Peter Daniel | Digital Source | 176 | 25th September 2003 07:40 AM |
