Go Back   Home > Forums > Source & Line > Analog Line Level
Old 25th December 2012, 06:56 AM   #381
mebexno is offline mebexno  Indonesia
mebexno's Avatar
by schematic Apex MX1, I use to stereo to mono preamp.
I combine it with the B500. results signal sounded perfect and does not eliminate the original frequency. thanks Mile. sorry my bad english.
sir mile, should I replace the R input 22k? for better sound?
Old 28th December 2012, 07:29 AM   #382
helo apex,
by the time i mange to get camera pls see how much ml3 i make.tnx
Old 28th December 2012, 05:14 PM   #383
DAMANHURI's Avatar
Lightbulb My First Tube Amp
I've tried it with the specifications provided by APEX, but I have a problem on Mute / Operate Relay does not work and the red indicator lights up, if you can help me APEX? I question my view on the schematic point 4 da 5 connected goto +6.3 V and point 9 to the ground, but the PCB layout I created only 4 only connect dots and point 5 is not connected to any section. please help Mr. Mile. sorry my bad language.
regards
Damanhuri
Old 29th December 2012, 04:16 AM   #384
mrching is offline mrching  Philippines
mrching's Avatar
Send a message via Yahoo to mrching
hello apex do you have echo circuit for diy? can you share it?
Old 31st March 2013, 07:37 PM   #385
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Default APEX FAN CONTROL
Just want to share for all diy freind may need this APEX fan control.
Old 4th April 2013, 11:50 PM   #386
abetir is offline abetir  Philippines
Thank You Wil!
..been waiting for this one..
TY!
Old 18th April 2013, 06:05 AM   #387
france is offline france  Philippines
Default echo
echo circuit post here are ok i tried already ic pt2399
Old 20th April 2013, 04:25 PM   #388
panggih is offline panggih  Indonesia
anyone please help me,what is the problem with mine ML3, when pot to minimum but still audible voice?
Old 1st May 2013, 03:51 PM   #389
Lightbulb PRE-AMPLIFIER-* FJROMERO
The creator of this preamplifier is known in this forum:
FJROMERO
Originally Posted by apexaudio View Post
In this thread I will post preamps, EQ, active x-overs, VU...
ML3 is Mic/Line XLR preamp with three band EQ +/-20dB
PCB size 100x40mm
Share this preamp:
Design of Sr: TUPOLEV.
Redesign: YIROSHI
also can be found on the website of video jukebox.
stereo preamplifier
VIDEO ROCKOLA
pdf format
------------------------------------http://foroselectronica.foroperu.org/
help with single supply for two EQ/preamps lassoharp Power Supplies 3 9th July 2009 03:24 PM
HELP with PHONO and MIC preamps. P Lazkao Tubes / Valves 10 23rd June 2006 01:42 PM
measurement programs, mics and mic preamps. j.burtt Multi-Way 11 15th November 2005 08:08 PM
Power supplies in mic tube preamps JamMan Tubes / Valves 5 2nd November 2004 02:48 PM
mic preamps travis Solid State 7 20th May 2002 05:59 PM
Copyright ©1999-2013 diyAudio
