| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#331 |
#332 | |
but how to mastering,can u help me for ML3 to Mixer if any schema? sory my bad english...thkks regards |
#333 |
sir i want to build mini mixer 6ch with ure apex ml3...
#334 | |
but how to mastering,can u help me for if any schema? sory my bad english...thkks regards |
#335 |
#336 | |
You don't read from the beginning. i help you a little. Pictures for apex ml3, regulated psu 2x15v, and master mix. I recomend you to use tl072, tl074 like the scematics, never use the others ic because it can give more noise.
#337 |
#338 |
Mr. Mile, i need distributor audio with 4 output chanel every mono, please give me the skema and layout. Thank you
#339 |
good afternoon mr mile, can you
post it MX1 component layout to us? Thank you. Regards |
#340 |
my preamp ML3 with standar part in lokal state
| help with single supply for two EQ/preamps | lassoharp | Power Supplies | 3 | 9th July 2009 03:24 PM |
| HELP with PHONO and MIC preamps. | P Lazkao | Tubes / Valves | 10 | 23rd June 2006 01:42 PM |
| measurement programs, mics and mic preamps. | j.burtt | Multi-Way | 11 | 15th November 2005 08:08 PM |
| Power supplies in mic tube preamps | JamMan | Tubes / Valves | 5 | 2nd November 2004 02:48 PM |
| mic preamps | travis | Solid State | 7 | 20th May 2002 05:59 PM |
