Go Back   Home > Forums > Source & Line > Analog Line Level
Old 22nd January 2013, 11:44 AM   #33281
Esperado's Avatar
Originally Posted by RNMarsh View Post
Flattening the peak added damping as well and combination always tended to make the sound 'dull'
I always liked the midrange flat. -Thx RNMarsh
That is my experience too. For the same reason, i found some heads, if i remember well, had a better 'opened sound' loaded with 100K instead of 47, depending of the capacitance of the wires..
The sound was very different from one head to an other, one arm to an other, changing with stylus pressure, kind of diamond used, and even plate's resonances...
Despite my automated radial arm turntable modified with a carbon fiber cleaning brush on the chariot, it is always scary to manipulate those precious vinyls.
I'm glad to the Digital industry to get rid of all those problems.
Christophe.
Ultimate Protection
Old 22nd January 2013, 11:52 AM   #33282
mkc is online now mkc  Denmark
Hi Pavel,
What measurement equipment are you using? It doesn't appear to be your normal plots.
Thanks,
Mogens
Old 22nd January 2013, 12:00 PM   #33283
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by mkc View Post
Hi Pavel,
Thanks,
Mogens
Hi Mogens,
already replied here:
I bought a new software to get reliable results in SNR and NL. It also generates clean signals (ref. Fs and FFT length) and uses rectangle window, more in the manual.
Old 22nd January 2013, 12:16 PM   #33284
PMA's Avatar
Default OP27
Low noise but high distortion and higher order distortion. The last one in my test
Old 22nd January 2013, 12:36 PM   #33285
Esperado's Avatar
Many thanks, PMA, for sharing your measurements. Once again, it prove all those evil little black boxes works damn well !
Christophe.
Ultimate Protection
Old 22nd January 2013, 12:41 PM   #33286
SY's Avatar
Originally Posted by PMA View Post
And finally, OPA637. Low distortion, low noise and low sensitivity to interference. My vote
No 7th!!
I guess it's suitable for mid-fi. The only way it could work for High End is to hide it inside some mysterious box and tell a good story.
If there's a sucker born every minute, where do the rest of them come from?
Old 22nd January 2013, 12:55 PM   #33287
PMA's Avatar
A good story is all we want, isn't it?
Old 22nd January 2013, 01:07 PM   #33288
Esperado's Avatar
Time to confess, now.
In 70s, our boss was putting much pressure on us (r&d office) to offer some quadraphonic feature to our market (hype at this time, while no quadraphonic records were available) .
So we added in one of our amplifiers some resistances to feed 2 extra loudspeakers to be situated back to the listener's place, with the difference signal of the main amplifier (each added loudspeaker in phase opposition).
L, R, (L-R),( R-L).
As we were very shamed with it, the resistances where hidden in resin. Of course, we let the marketing department free to compose the marvelous story and benefits of our mysterious black box.
I hope this will be forgotten or forgiven the day i will do a job ask at the Paradise's door.
Christophe.
Ultimate Protection
Old 22nd January 2013, 01:37 PM   #33289
jneutron's Avatar
Originally Posted by gpapag View Post
jn
You have all my respect when it comes to EM.
But this generation of harmonics didn’t cling to me from the start.
I have some days now reading back Heaviside’s Electromagnetic Theory and I didn’t find any supportive evidence. The closest to the subject is para 191, pages 344-349 (*) of Vol. I (I haven’t looked at his Electrical Papers yet).
The explanation you give here (in bold letters)
is central to your reasoning.
I want to ask:
1. Is what you suggest a result of experiments or of theory?
2. In case of experiments Is it possible that harmonics are caused by (a) heat diffusion velocity effects in the conductors and/or (b) attraction - repulsion forces causing minute distance modulation btn conductors?
George
Answers.
1. Both. Most people would just be happy measuring Ls/Rs, and assuming that Rs is simply a frequency born effect. It's a reasonable approximation, and one generally used with switchmode supply modelling for dissipation within the conductors due to proximity. My applications are significantly more shall we say, sensitive, to the effect.
2. I would assume so, but the level of effect has a huge negative exponent. The thermal mass of most materials and the thermal conductivity cause very slow diffusion velocities. Even for copper, it is quite low.
My understanding is that if electr. conductivity is very high (and magn. permeability is 1), this time varying resistance will be synchrounous and with no delay in respect with the excitation, thus it will affect current only in amplitude - and this a little- and not generate new frequencies
The rate of change of the magnetic field is the time derivative of the current. So the resistance will be maximum while the current is passing through zero in both directions.
Originally Posted by jcx View Post
the resistance doesn't change, the (partial, spatially varying) mutual inductance with the proximity current causes emf (also spatially varying) that appears to redistribute the current through the sheet of the physically distributed resistance (quite accurate)
the appearance of the current "being shoved to one side" only happens with identical waveforms in the wire and the sheet resistance
very close. The "shoved to one side" is actually the result of the summation of currents... The current within the resistor summing with the surface currents being generated within the conductive film of the resistor, faradays law of induction. This is why I also mentioned the amplitude modulation of the resistor voltage as a result of a non correlated time varying magnetic field attacking the resistive element.)
Originally Posted by DF96 View Post
If it is rate of change of current, as jn asserts, rather than frequency, as the textbooks say, then the penetration of current would vary through the cycle. This would mean that any RF or microwave system would generate second harmonic whenever RF encountered a conductor, as the current density would be varying at twice the frequency. I am not aware of this phenomenon ever being reported.
Do not confuse skin based effect with proximity caused by an external magnetic field. Faraday seems to disagree with your assertion.
I am baffled why jn continues to assert something which is simply false. The maths is quite clear: the geometric distribution of current depends on frequency alone.
It is important to consider the polarities of both the current and the current derivative. You are not.
Where a sharp pulse is concerned then the individual frequency components (e.g. f, 3f, 5f etc. for a square wave) each have their individual exponential decay into the conductor. This means of course that a sharper pulse may penetrate less but this is because of its higher frequency components not its greater amplitude.
You use a higher slew rate current as an example, but then claim it's frequency and not slew rate??.
I am getting bored with this. There is a point beyond which it is not worth repeatedly asserting known EM theory to someone who rejects it.
Having quite a bit of experience in theory, modelling, building, and testing this kind of stuff, I find the assertion that I reject EM theory as funny.
Perhaps you should contact someone who does this other than me . Sullivan at Dartmouth would be a good one.
Originally Posted by magnoman View Post
jn,
That would help but I think I'm following your basic argument just not quite how it produces a second.
If one accepts the dI/dT dependency and that this effect only increases the crowding resistance then I can understand how for a sinewave this would result in cos modulation from the dI/dT and the absolute value to account for only increasing resistance.
But from there I see this modulation producing steeper slopes around the cross-overs, local minimums at the peaks, all symmetrical between positive and negative going cycles of the sinewave. Why wouldn't this symmetry measure as a dominant 3rd?
Because the current within the resistor swaps polarity at the exact same rate as the current which drives the time varying field. The end effect is the current will be "pulled" towards the driving wire during both polarities.
I think DF's problem is he (and others) are thinking along the lines of Hall effect. When the modulating field is the same signal as the resistance current, you have to rethink the problem.
jn
Old 22nd January 2013, 01:38 PM   #33290
Well, PMA, thanks for your discovery of the OPA637. Unfortunately it is 5 times the price of what I am using, and is 10dB noisier. However, for MM cartridges ONLY, it is just about perfect.
I don't know why I am constantly being confronted about the 'marketing' of my designs. It's true! Manufacturers MARKET my designs. They praise my name to the stars, and give many of my designs attributes that I never thought of, and if I look at their 'claims' seriously, I sometimes wince. However, I don't participate in marketing, seldom confer with the 'marketeers' and even then, only on technical matters.
I am told to: Get out of the way and to leave the marketing to others. I am never supposed to criticize my own designs. My bosses send me nasty letters when I do so.
So there it is: The free market of audio with different groups 'hyping' their designs, hoping that they will get enough sales to keep the company going in this economy. I'll participate in none of it.
What I HAVE tried to show here, is the 'subtle stuff' sometimes even ignored by the manufacturers of my designs, to their own peril. Because IF they ignore the 'subtle stuff' the audio product will often FAIL in the marketplace, both with reviewers and the general public.
Enough 'failures' and there is no further company. I have been threatened with dismissal several times for the 'failures' but I have always been able to 'save' the design concept at least with a 'successful' almost identical design made with my 'subtle changes' added.
This is true of the JC-1, JC-2, and the JC-3 from Parasound. However, other designs, even initially done by me, are not in my direct control, and can be compromised by the builders in Taiwan, to save, time, money, whatever. Yet, the examples of the JC branded products usually trickles down to the less expensive models, and usually a pretty good product is produced, thank goodness. This is my reality, accept it or leave me alone, please.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
