| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
| Thread Tools | Search this Thread |
#2181 |
Studies, are not everything. Success it.
#2182 |
I have not seen any evidence that special RF ingress protection is or ever was the key toward a successful audio product. To me, such special protections are just another attempt "to make a difference" on a market where differentiating from your competitor is a critical factor. Otherwise said, just another sales pitch, good for the Stereophile readers.
Do you have such evidence? Last edited by syn08; 2nd November 2009 at 11:52 PM. |
#2183 | |
Here's something John might like. A quote from someone's presentation: "The AudioFool Viewpoint • The Myth: “We can hear stuff above 20 kHz” • Reality: Some distortion mechanisms DO produce audible artifacts from ultrasonic signals, but we hear the problems, not the signals! • Intermodulation distortion (40 kHz – 30 kHz = 10 kHz) • Slew rate limiting within electronics of ultrasonic output of a mic (or of square waves from a test generator)" The rest can be found here http://audiosystemsgroup.com/Ferrites-Ham.pdf It all sounds quite reasonable to a noob like me. What do you guys think? |
#2184 |
OK, by the same fellow, named Jim Brown, who gave a presentation at the 2008 Fall Convention of the Audio Engineering Society in San Francisco.
http://audiosystemsgroup.com/AES-RFI-SF08.pdf Seems like a worthwhile presentation to have attended. |
#2185 | ||||
Hi Kannan,
If you read syn08's post, copied here: Quote:
The susceptibility of the circuits that comprise the equipment will determine how much injected noise is acceptable. Quote:
Never assume anything. Quote:
Look at any good piece of test equipment for clues. What you will see is generally far more attention paid to shielding and power supplies. If you then have a peek at some consumer audio equipment, you should be able to see clearly what the differences are. Last point. Noise reduction from interference is a money game also. How far do you go? How much money is spent on the pretty box? How far down your noise floor is depends on how much money and research goes into the design (= money). Everything is a trade-off. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#2186 |
Hi ikoflexer,
Jim Brown is a smart cookie. His stuff is well worth reading and he has a wealth of information on his site. I'd recommend you start reading. Remember to keep a perspective on what effects they are talking about. His concepts are solid and based in reality from what I can recall. -Chris
#2187 |
To minimize confusion here, I have found virtually everything is important in serious audio design. RF contamination is just one thing.
I would like to point out that of the 3 stages: We are now at stage 2. This is: 'It exists, but it is not important' IF you want to read anything further on AC line contamination, I recommend getting and reading the IBM article from the IEEE from Ikoflexer. Thanks Ike! |
#2188 |
Yesterday I forgot to show the measurement extended to 1GHz. We can see FM broadcast, TV broadcast and GSM in the PSU output spectrum. Of course, the very high frequencies are coupled from the air.
#2189 | |
jd
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#2190 | |
And what about the spectra from 10-20GHz? There are Ku band satellite DTH TV broadcasts there, high power transponders with 27 MHz bandwidth, carrying digital signals. Those are much powerful than the next GSM tower! Not to mention the evil Ka band at some 54GHz. So? Should we get tin foil helmets? Should we encase our amps in Faraday cages? |
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| john curl, riccoryder |
| Page generated in 0.28015 seconds (65.88% PHP - 34.12% MySQL) with 11 queries |
