| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I am planning to build a passive pre amplifier. The design I am having in my mind is the one with a potentiometer and 2 transformers. I am planning to use an ALPS 100K log potentiometer. But, I am not so sure on the transformer configuration. Can some one contribute/suggest ? Regards, Bins |
#2 |
Please suggest me a suitable transformer that can be used for the passive pre-amp that I am designing. The input will be provided from a DAC/CD player. My power amplifier has the following ratings: * Input impedance (unbalanced): 10 K Ohms * Input sensitivity: 100 mV to 775 mV. Best regards, Bins. |
#3 |
Hi Bins,
I'm wondering why you want to use a pot with transformers. Why not use tapped transformers by themselves? John |
#4 |
Hi John,
I am not sure on how to design that. Can you give me a circuit/model that I can look at ? Best regards, Bins. |
#5 |
Richard Murdey
A passive preamplifier ... okay, but idea from the start, but lets see where this goes...
A 100k log pot as a volume the volume control. So far so good. The input impedance of your "line attenuator" is about 100k. The output impedance is 0-25k. If the interconnects are kept really short, your amplifier, with an input impedance of 100k, will be a decent match. Now, for some reason you want to use output transformers. You can use them as step-up transformers or step-down transformers. Funnily enough, neither configuration makes any sense. If you need more gain (step up) it would be more efficient to turn up the volume control. (The output impedance increases either way.) If you need lower output impedance (step down) it would be more efficient to turn down the volume control! (The output signal level decreases either way.) You could use the transformers as 1:1 isolation units, converting the signal to balanced for the output. That gives you some immunity from ground loops and noise, but you won't find any that have input impedances much above 10k, so it's a really lousy idea to run them directly from the 100k volume pot, your frequency response tanks and, to add insult to injury, varies with the volume position. And you still can't drive any reasonable length of interconnect! To paraphrase Steve Jobs, passive line stages are a a bag of hurt. The only way to do it properly would be to drill a hole in your amplifier faceplate and retrofit in the volume control. Then build a passive line selector box. Amplifiers should be driven by competently designed active line stages. The end.
RJM Audio (phonoclone.com) |
#6 | |
Trust me on that , been there done that = a lot of crap ! But if you consider : 1 transformer and then the Alps 100k it is ok . Done also that ! Good configuration . You must to know when to much is tooo much . Or as suggested by fellows just one transformer with a lot of taps and a good switch and discard the Alps . Last edited by danzup; 19th September 2009 at 11:18 AM. |
#7 |
The original idea to develop a passive preamplifier using transformers has been called off in favor of George's light speed attenuator..... Best regards, Bins. |
#8 | |
#9 |
Now you have gone another direction, the Jensen isomax transformers seem well received, especially following a CD player.
| Phase Linear 700 input section question | taj | Solid State | 1 | 10th July 2009 06:24 PM |
| passive I/V and transformer | D.A.R.R.Y.L. | Digital Source | 12 | 1st May 2006 11:42 AM |
| passive I/V directly into transformer ? | Bernhard | Digital Source | 6 | 17th August 2005 09:39 PM |
| PAssive preamplifier (volume attenuator) with Aleph 2? | vmajor | Pass Labs | 5 | 5th February 2005 07:03 PM |
| passive preamplifier newbie question | Jamh | Solid State | 3 | 2nd December 2003 06:38 PM |
| Page generated in 0.13420 seconds (80.46% PHP - 19.54% MySQL) with 11 queries |
