Scottmoose said:The druids had the right idea. Never be precise. That way, nobody knows exactly what you said, so you can always change it.
Oh the irony!
They claim 101dB, 35Hz-30kHz...
but don't specify -20dB range on that spec)
Reminds me of Lowther (see attached measure of an EX3).
It's called being economical with the old acualite. You make a truthful statement, but ensure you are also very careful not to say too much. Like how you specify something. 99.99% of companies pull that one. For example, the F15E Eagle is claimed to be able to pull around Mach 2.2. It is of course, an interdictor that was built out of an air-superiority fighter, and would probably fall apart if you try to pull that on the deck, where it spends the majority of its life.
Scottmoose said:Eminence are the largest driver manufacturer in the world
I have seen that comment before -- it is not close to true. Seems Eminence makes 3-4 million speakers per year. It is estimated that Foster makes 10 million speaker a month just for Apple alone.
That said, i'd probably be more comfortable knowing that Eminence was making the drivers for Zu than Zu making them themself. Assembly of a driver from specified parts with extra QC is a different thing. What in the end is important is "how do they sound"
dave
