Re: Re: Re: thanks.
BA stands for Big A-s-s. Bruce is the Spawn BVR (Big Vent Reflex) for 8" drivers.
Scott & i are working on one for the Emenabe 12LTA -- a pair of which were donated to the frugal-horn site (thanx George) and which i just happen to have a set of phase plugs & a choice of helper tweeters for.
dave
blumenco said:what does that mean? other than the bruce part. assuming bruce edgar.
dave
I like it. Easy curves to do with a router. one template for the middle bit and a big circle cutting jig for the curves at the back. Thick sides with tracks cut into them. For the rest rip up a bunch of cheap planks into sticks on the table saw. You could even calculate the angle and cut trapezoidal sticks.
would 3/4 thick pine be suitable for the curves?
Don't know if 3/4" would be sufficient (i'm not the master woodworker) I just generated drawings and the visulaization.
Jerry (in Alert Bay) is building these out of treated 1 1/2" solid cedar. The curves are all going to be precut trapezoids barrell-staved togther
The CC is larger than needed and will need irregular shapes/solid fill inside to bring the volume back down.
dave
dave
Re: wow!
There is a chance they will be done for the July 28 diyFEST.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=100098
only a short drive and a ride on the ferry.
dave
blumenco said:that is awesome!
I would love to hear those some time...
Clark
dave
