Yet another DIY AMT
Oblivion
First test of diffracting back pole pieces:
ciRCs7AMJMueF52fXwtK3uDaKfMchRkLbYYTQilhH1w=w1920-h1056-no
Tests were made on Mk I.
To the left is the original back pole pieces (they are the same as those in front),
in the middle 2x15 mm iron rods that are cut and tilted where the magnet gap will be
and to the right some dampening material I put between the pole pieces.
This is the final setup with; cut and dampened:
DUGmRagf-77F4zodBG_hJKIeFZbU50LhbY7xK2BtlVo=w1704-h1137-no
nB58o5gnOrmqDrD3_bs5GGas8p1j-5MysC2-psyb52s=w1920-h974-no
Some measurements then. All done at 50 cm with 1 W. Smoothing 1/12.
Original back pole pieces (red) compared to the cut ones (blue):
7xl22c1zoTgRh73wFSRDcCkKqL2eEG0nuMj8orSaA0s=w1592-h848-no
Nothing much happened, just a shift down for the "hump".
Cut ones (red) vs with some dampening (blue):
zWcUGH4kfo1qRKzpWxkM3gT6SYsklnoPMVHHJ64lwmY=w1592-h848-no
Not any significant changes of the hump.
But overall was SPL reduced, so perhaps the reflected wave was reduced.
If so, it was at the cost of higher distortion levels, almost 15 dB for some frequencies.
Got some proper HVAC foam with 20 PPI from the local hardware store.
But the correct place is between the membrane and the back pole pieces.
So I must make space for the foam as it is 10 mm thick.
I also have to modify the Mk II motor at some point; the back pole pieces will have to go or at the least be replaced by a thinner pole piece in order to get less reflected area. Perhaps 2 mm instead of 5 mm.
So building a rather complex pole pieces with many small iron pieces lead to this:
(Spent one hour or two at FEMM to get this far)
Oqh8p0s2YXFzkJ8SQmkaOV_V6M7WGCHps5kY6V_Gx5o=w1147-h489-no
mM5KyRikEpBVMpcHCfOKFuWUmMROcxuxyTp-34JNrYY=w1127-h421-no
For sure not linear enough across the gap:
vddUBfM1g-SMjc6NFddFavr4cfKfrMyV62I2epUkk-A=w1577-h965-no
mQicY-C9v1U4uQ31qdXyDeW8iUEO0WfsGpW-PoBp55c=w1567-h979-no
It´ll be the double amount of magnets (total of 64) and the same size (N42 40x20x10 mm).
Finally :)snail:) got two bare Mk II B ready.
Two layers of magnets and only the front pole pieces permanently (I hope) mounted.
zWRCIXh4iF44SICBBJ0jsdOImgJCqLOqMyWmiKY6jGI=s800
6cYQ_Ech_duNzwoN0Tlk4KCCkraptO6GpOCUITJnM6M=s800
I've also tried to make an initial waveguide throat with glue sticks, couldn't finish it though as the glue gun melted and cut the power.
w5Jzw5RVE0vNJbne43BYFWjcS1brtuJf62T-gPwM4ys=s800
Not the prettiest things I've made but certainly two of the most lethal :eek:.
Now I can start experimenting with both size and shape and number of the back pole pieces.
Also the position of the membrane and HVAC foam in the now 20 mm gap.
But first some simulations...
Again, please note that for this fake motor, the corresponding real magnetic flux density is probably not even half of what is shown above.
So also the variations are a magnitude less, but should be able to be used for comparative studies.
In this fake, inverted, motor, the foils in the membrane are parallel with the red line so the Lorentz force is making the membrane's fold moving in and out in the paper's plane as the current varies with the applied signal.
It is not so good that this force then is varying along the fold.
Of course, if the fold is stiff enough it doesn't matter, but I suspect that there are modes that results in resonance patterns with resulting distortion as well.
Such modes will appear at frequencies corresponding to from 10 mm to 310 mm with a 10 mm granularity (cc of the pole pieces) plus the half and quarter wave lengths.
(And I guess 1/8 and so on as well but they will be of less amplitude and buried in the overall "noise" anyway.)
Many modes will of course be superimposed (that will be superimposed!) producing even higher dips and highs in the frequency response curve.
So the Mk II design (and Mk I!) was flawed from the beginning.
And of course all other simple bar AMTs out there.
One countermeasure is of course to go the Båndsei way of "Look, no bars", but that causes other problems such as weak and non-linear magnetic flux intensities.
Another way is to have the pole pieces at a not repetitive interval but that will only reduce the superimposed modes, not removing the actual modes.
A third way is to... Sorry, that will be another time. Or, quoting another famous monologue: "II B or not II B".
If the foam is pushed back, perhaps with cutouts for the back pole pieces, there will be less dampening and diffraction of the back wave and its reflection on the back pole pieces.
One remedy for the lost diffraction is so make the back pole pieces edges not so blunt:
BgqQ-dlWHZkase6TffU6g4RBta3kI3kbjYTic_97zWc=s800
Simulated:
DYQw0Fe26kNcapwlXlK842oIYYagkRI2_tHIT-gZjrA=s800
Flux density variation in the center of a membrane in the middle of the gap:
StBuj6-HO-QCqBBZKczbnC_KkIaQ86w0421RUWCiGAY=s800
and at the rim:
8t2NpSH-nCIP1KEJBEGG-VZK0t9u7ZeosPeDgr2JjnQ=s800
Now this looks promising.
