Have you looked at the datasheets of each of the valves?
Can you identify the heater-to-cathode voltage for the existing setup, and for when you change the heater elevation from 0V to say +90V?
Is the amp working ok at the moment?
Can you rewire heaters from separate valves to the other heater supply easily?
In the datasheet of 6SN7 the max. Uk-h is 200V.
I was worried about voltage values of the schematic that I found on the web.
Single measurement was made with final tubes, KT88, removed from sockets, I measured in a socket, for 232Vac network I found plate voltage 465Vdc and heater voltage 6,9Vac. The amplifier works well, I have it about three years. Over time I rolled-on all the tubes. I had problems with some 6SN7 JJ, after warming they crackling and humming. In the same places 6SN7 Tungsol work well. After I'm finding the best solution I'll rewire heaters, I can do this.
Yes many datasheets say 200V, but a few :In the datasheet of 6SN7 the max. Uk-h is 200V.
https://frank.pocnet.net/sheets/191/6/6SN7GTB.pdf ( RCA )
says that the DC/average should not exceed 100V.
Cracking and/or humming is a symptom of broken down isolation between
filament and catode.
Go for elevated filemanets, get a separate filament transformer if needed.
In electronic diagram the power outlet median filament winding is grounded. Filaments potential is almost 0V (actually 3,15V) so voltage between cathodes and filaments are approximately those given in scheme, 283V for cathode followers, 173V for phase inverter, for second SRPP cathode can be calculated taking into account the internal resistance of the tube. To find exact values I will remove cover and will do measurements. I think the solution is to realize two separate filament transformers. Thanks.
I have decided to keep the original heater supply for KT88 valves since the voltage between filament cathode is 500mV and to make heater elevation for 6SN7 and 12AX7 valves. For this I made two toroidal transformers, one for each channel. For each, primary winding fed to 6,3V to keep consumption and for easier winding and secondary : 2x3,15V, 2x6,3V and 2x7,5V. In this way for the filament supply of 12AX7 tube I will be able to use 6,3V ac or 12,6V ac, the median filament grounded, or 12,6Vcc stabilized.
These are transformers:
Because voltage network at my house varies between 232...240 V, filament voltage reached 6,9...7V, I realized transformers with a transformation ratio slighty below par and in KT88's filaments supply lines I tied resistors in series. Now filament voltages not exceedind 6,5V. Other modifications: have rotated 90 degrees power transformers, have mounted EMI filter to the mains supply, have mounted a soft-start circuit. All changes can be seen in photo:
No Yaqin amplifier here, but if I did have one, I would probably do the type of changes you are implementing on your amp...nice work!
My current project, which has been interrupted by our bathroom remodel (what!), is a pair of new monoblocks: 6CG7 voltage amp - 12BH7 LT Phase splitter - KT88 output. Transcendar and Hammond transformers.
New construction sure is time-consuming, but also rewarding... Generally, I prefer to modify existing designs, like you are doing here.
- Tubes / Valves
- Yaqin MC-100B heater elevation
