hey guys,
finally finished my desktop-speakers for use with my laptop. THey're using visaton frs-8 drivers (dirt cheap and not that bad) and go down to about 100 hz so i decided i needed a small sub. Finished that too; picked up a second hand vifa pl18w009-8 (yay!) pretty cheap and put it in a 15 liter vented box.
And now, the xover. I decided on an active linkwitz/riley filter at about 110-120 hz and came up with this:
top and bottom blocks are highpass filters for stereo speakers, mid block starts off with a summing amplifier. last two opamps are the lowpass filter. In front of the summing amp are 2 100k resistors. First opamp in the top and bottom block use 100k to ground on the inputs.
Assuming that i can work out the correct values for the filters with rod elliott's l/r calculator (yay for rod!), is the rest of this schematic correct? In other words; will this work?
what kind of signal-level loss can i expect after the lowpass section? I presume that with the highpass section signal loss isn;t that bad.
Inverted topology is used for correct summing function without influences in channels crosstalk.
http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/opampvar5.html
- xover question; will this work?
