Kornny any updates? I have four 18nw100 for this design waiting for dry weather
Not was yet, at this moment I am working on something else.
fyi
just simmed the 18nw100 .
it works great in this sub ,you can put a high pass at a verry low 25 hz with this driver.
i think cressendo bild a couple of them.
Thanks Epa
Hi Y'all,
What were the results of the test boxes for the 6-Fold, and is there a consensus as to preference between the 6-Fold (30Hz), and the TH-18 (35Hz)?
Oliver
I did not get a chance to build the 6fold tapped horn. I just finish building my first tapped horn for a friend using 18 sound lw1400. My friend was so amazed with the bass he ask me to build 6 more for him. Enough respect to epa for the design.The crazy bass
glad to hear you like them.Oliver
Hi kornnylike and epa,
That looks interesting, I saw the pictures in the "18TBX100 vs 2lab12" thread:
http://www.diyaudio.com/forums/subwoofers/201249-18tbx100-vs-2lab12-19.html . Are there any drawings for this one?
Otherwise, no one has build a test box for the 6-Fold yet? Is that because the Xoc1 TH18 is considered better?
Oliver,Otherwise, no one has build a test box for the 6-Fold yet? Is that because the Xoc1 TH18 is considered better?
It appears that the amount of cabinets actually built is inversely proportional to the cabinet volume.
Pasc built the Xoc1 TH18, and the slightly larger Keystone, which he preferred.
Both are sitting in a garage, while he uses smaller cabinets using cheaper cones that don't go as low, but still have plenty of upper bass, to save his back.
Art
tb46, epa & everyone else,
I built the 6 Fold test box, remember?
Played low notes very well, but not quite enough overall output for my space-to-output needs. A lot of music we have contains very low notes, but not many of those songs are songs we would play out at a show. For me/us, the TH-18s were our best bet for our DnB, dubstep & other bass music shows.
there is not much difference,besides the tuning and size.Anyone
What is the difference b etween a symmetic tapped horn vs th18 vs 6fold
Which one give off better bass response and have sound quality
the symetric uses a litle more wood ,but has a L1>L2 of 0,01 ,wich can be an advantage.
hi oliverHi epa,
Thanks for the drawings. Did you work any more on the cone correction? This cabinet seems to be a natural for that. By the way, what is the width of the cabinet?
in the testbox i bild i didnt use a correction,it was fine the way it was.
agreed its easy to put a piramid in the center.
internal pannels are 19.5 "(50cm) wide
hi justintb46, epa & everyone else,
actualy i seemed to remember that,but i couldn't find it.
so i asumed it wasn't so.
is the th 118 louder then the 6 section 30 hz?
i remember it was about 200ltrs bigger.
Hi epa,
Thanks for the additional information, did you have a chance to do any measurements you can share?
i took some quick measurements here.
this cab was designed for a different driver.
but i had the 18lw1400 at hand.
the one kornie bild is more optimised for the 18lw1400.
- Subwoofers
- Xoc1 6F TH
