Thanks for your consideration; I'm trying to complete a pair of JBL L100t speakers. The 2214H is the stock LF driver, but I've read that the 128H is a valid sonic replacement, if you aren't rigid about only using stock components.
I'd also be interested in rebuildable versions of these if you've just never got around to the project you were going to use them for. <G>
I have two early JBL LE8T drivers (16 ohm, and need foam) with correct ohm values available to consider as part of the deal, if that helps.
thanks,
Wornears
thanks,
Wornears
