Would the active crossover suffer
This is what I intend to connect the one LOW output from the active crossover to a two channel power amp. Which connection you would pick case A or case B?
Will I be hurting the crossover by asking it to drive two channel amps from one output? ie four channels for left and right.
Please check the 15k diagram.
Thanks in advance,
Chris
