WMTMW Center Channel Crossover Changes
Joined 2011
Here is my idea, RS28FT with RS100T-8 in MTM, Those will be flanked by a pair of DA175's.
Would there be any crossover changes if I went to a vertical arrangement that was MTMWW?
I'd be looking at something like a 500 - 5k crossover.
Just another Moderator
Joined 2003
It would be interesting to see the polar response of that configuration (especially a 3d one). the mtm will give narrow vertical dispersion and the W W on either side will then also tend to give narrow horizontal dispersion... I'm not sure though whether it will be less of an issue due to the lower frequencies involved with the W's... what frequency were you thinking of making the lower crossover?
Tony.
Joined 2011
The sample crossover shows a 500hz & 5k crossover points.
I have drawn up a simulation based on the DA175 & Alpair 6p in a 2.5 way sealed for the center and vented for the mains.
It really looks quite good I think.
I still need to get a grasp on how to cascade the second woofer properly for a good .5 way.
Here is the MTM mains setup I'm working on along those lines.
