Thread Jacking.....
Charlie,
I'm sorry if I have inadvertently jacked your thread.
You have been where I am recently so I thought you could shed some easy to understand light on how to build this PS.
I thank everyone who had input and suggestions for me. Thank you.
New thread will be started about this Biasing B+ on the Aikido.
I don't want to be a jacker.....No offense Jackinnj.
Ron
Edit:
Fran, the pot in there is as suggested by SY in posts 7 & 11
Ron
Charlie,
Ron
Edit:
Ron
Charlie,
I apologize to continue in your thread. Since Sy's post is here, it is more convenient to reply here.
The trim pot that Sy mentioned in post #7 is not for tuning the voltage divider for the heater. You don't need a pot there. The trim pot is used to tune this formula R15 = R16 * (mu - 2) / (mu + 2) as close as possible. For the purpose of fine tuning R15 and R16, diagram 2 is how the trim pot is placed.
Remove the diode, you don't get a B- like that, your B- is the ground which is connected to the bottom of the voltage divider string. If the cap in // to the voltage divider is used to ground the floating heater, then the upper part should be connected to the middle of the divider rather than the B+.
Again, sorry Charlie
Fred,
thanks for the continued help. I appreciate it.
Please look at my new thread, here:
Non-hijacked thread
Ron
Fred,
Non-hijacked thread
Ron
cbutterworth said:
At some point, I'll rehouse my Aikido and use aluminum for the chassis plate rather then the steel used at present.
Charlie
Could it be the transfos are coupling thru the steel plate to your components? Have you tried moving the transfos away or their alignment?
-Kent
