Hello all --
Not sure if this has already been discussed. I am using power tubes that use a cap on the top for the plate. What is the best way to build the wires for this purpose? Should I use shielded wire? What type of insulation is best? cotton? teflon? How about gauge? Stranded or solid?? Thx much!
Well insulated (proper voltage rating for application) to eliminate the possibility of electrical shock due to inadvertant contact. Flexible (stranded) IMO because you don't want the wire to break with repeated removal and installation of the plate cap. I like teflon insulation for its heat resistance and dielectric qualities. Not shielded generally because of the effect of unwanted capacitance in the plate circuit. Gauge is generally not critical..
High voltage rated should go without saying, but I'll mention it any way. Rubber gromet at the feed through. Cage over the tubes when done.
I'd be inclined to use 22AWG or 24AWG multi strand 1KV or better wire unless it were some monster amp. If you have a topcap, you are running real HV so watch for corona.
Hmm .. not sure I know about this ... can you elaborate a little? Does this happen because of the cap? The tube I am using is a GU-32 (832). It doesn't really have a cap really -- more like a stout wire coming out of the top. Where does the corona form?
Looking at a plate voltage around 250-300V if that helps.
I have some high voltage silver teflon wire I think I will use (22ga). Thx Kevin. For the terminator I have a nice silvered wire "stud" that has compression "fingers" on one end and a hole for the other to attach the wire. I have been able to form the compression fingers to make a solid connection around the plate. Was planning multiple layers of shrink wrap on top unless this "corona effect" blows that idea up.
300V should not be a real big issue. Use 600V rated wire. I was thinking of 500-800V plate supplies.
Corona occurs mostly when there is a sharp point or perturbance in an otherwise smooth surface with a high charge. It is a self discharge to the air. It is more likely to occur with HF present (I remember a lot of corona around the flyback supplies on TVs running 17KHz?? or somewhere close to that with 22KV supplies). We used to use Corona Dope on the solder joints.
Amazon.com: GC Electronics 10-4702: GC Corona Dope, 2-oz. Bottle: Home Improvement
Heat shrink tubing should be good at 300V, especially with multiple layers.
A ceramic cap is nice if you can find one to fit.
Ach! You beat me to it while I was looking for Corona Dope.
Corona dope
Thx Geek -- looks like cheap entertainment (whats one more noxious fume in the lab anyway right? ). Think I will get some unless it deadens signal or something.
There are ceramic caps for this tube I guess -but they are crazy $$$$. Was thinking of finding a ceramic jewelry bead of some type and slipping it over the warm shrink wrap for looks.
Hello all --
Here's my favorite method. I use test probe wire, because it's tough, flexible, and rated for pretty much any voltage I want to use. Through the chassis I use a "snub bushing" which is a 2 piece grommet that goes around the wire and pushes into a hole in the chassis, compressing and locking the wire in place.
Michael
What's a good source for the flexible test lead wire in low quantity (preferably by the foot/meter)?
I too like test lead wire from Belden, #8899. It's 5KV 18 gauge rubber covered. I get it on eBay when it shows up. I also like Markel #3239 silicone covered. Very heat resistant (150ºC) and very flexible. Good to 30KV but not too thick. There is someone on eBay in China selling HV wire that appears very similar and in various sizes. I've never used it though so I can't be totally sure what it's like. Search for *high voltage* (under business and industrial) and you'll find it in short lenghts.
Hello all --
Hi moonbird ,
When connecting tube caps , I ALWAYS use SILICONE insulated , stranded wire, rated for 300º C , 1.0 or 1.5 mm2 , and a ceramic cap ( forget about
any plastic insulation for the wire or the cap ,like PVC , mylar , etc , all of them will melt ) . You can buy it by meters ( or feet ) , in any good store that sells electric cables .
Minimum rated voltage insulation : 750 Volts
Teflon is also very good , but the price is high .
Carlos
- Tubes / Valves
- Wire construction for capped tube plates
