Wire colour convention
PRR
Joined 2003
Looking to buy some wire but how many colours is ideal?...
For real chassis clarity, 10 colors is a start, but more can be useful. (Peel your car wires out. Most are at least one stripe on body color; 100 potential codes.)
AND for doing all types of electronics you want every-other common gauge between #16 and #26: four or five gauges.
There are uses for both solid and stranded.
So now I have you buying 200++ spools. The Red and Black #18 and #22 will run out in a month, the pink/purple #28 will go to your heirs when you leave this world.
OTOH, some aircraft are all-White wire. Very confusing, but resists fire.
You can never have too much Red, Black, White, Green, and maybe Blue.
One big gauge and one small gauge will cover 90+% of needs.
PRR
Joined 2003
...Is there a convention?
Many.
AC mains:
Live: brown
Neutral: blue
Ground: green-yellow
AC secondaries:
Live: ?
Neutral: ?
DC low voltage:
Positive: ?
Negative: ?
Ground: ?
Are you actually wiring MAINS? Or winding transformers? Inside a chassis, we normally use the wire on the line-cord and transformer we bought. Jumpers for IEC inlet fuse switch can generally be harvested from excess (spare line cords are cheaper than buying line-grade wire).
BTW: brown/blue is now standard in most of the world, but older UK is different, and US/Can runs Black/White or even Black/Black (in older chassis and transformers or in very-very old wall-work).
PT to rectifier should usually be short so will often use the PT's own wire.
PRR
Joined 2003
