What could I expect if I was to add another identical driver to my sub box. It's 77L tuned to 20Hz at the moment.
It's a DF design but I'm considering adding the other driver on the smaller vertical face/baffle.
Or
Should I build another Identical box and locate it somewhere else in my room?
Or
A bigger box (200L) and have them both DF?
The driver bottoms out when I play films REALLY loud so adding another driver seems like the best option, to me.
It's pictured here http://www.diyaudio.com/forums/showthread.php?s=&threadid=100701
Or
Or
Adding a driver to your existing box is not really an option.
Either build a box twice the volume (mount the drivers on opposite sides to benefit from push push vibration control)
Or build a second identical enclosure.
Personally I'd do the first option, then if it's still not got enough welly build another 2 driver enclosure for a total of 4 drivers.
Rob.
Rob.
RobWells said:Adding a driver to your existing box is not really an option.
Rob.
I like the way you think. 4 drivers!
Thanks for the advice, I like the opposite sides idea.
Rich.
Rich.
Planet10 Daves been pushing that idea for years - I'm just quoting him.
Rob.
So with a push-push configuration should the drivers be in separate chambers or share the same internal air-space?
Also, that's going to shift a mighty amount of air so would it be wise to use a large sealed box or use a couple of pretty large ports?
I prefer the ported design as it kind of eliminates the need for EQ.
Rich.
Rich.
richie00boy said:Sealed vs vented really depends on the specs of your driver - post them up.
I have a pair of these: http://www.bkelec.com/HiFi/drive_units/bsb/monolith_du.htm
Am I correct in thinking I need to double the size of my box to accomodate 2 drivers? Otherwise box response will be reduced.
If this is indeed the case, surely it would be better to have 2 seperate enclosures which can be in different positions in my room.
Based on a 100L ported box tuned to 20Hz i'm thinking that rather than having a massive 200L box, 2 100L boxes might give me more flexibility with the same performance????
richie00boy said:Yes, yes and yes
By sticking with downfiring you drastically reduce the walking tendency, so push-push is not needed.
Great stuff, off to the timber merchant tomorrow then.
Any recommendations of where to get good ports in the uk?, I could just use pvc pipe but I'd like flared ends if possible.
the slow way is coarse grit glass paper, although aluminium oxide will last longer and cut faster.Marsh said:
I used pvc 4" pipe and 3/4" round over bit to flare the ends... worked fine
not sure what you mean. Can you post a picture?
If you put the pipe into the panel flush to the external side, then use a 3/4 inch roundover bit in a router to round the hole like you would round an edge of a panel.
Probably not quite the radius of flare you were looking for though.
What frequency are you looking to tune to? 4 inch might be big enough if it's pretty low.
Personally I'm not bothered about flares that much - you need them each side of the pipe to be 'doing it right'. Putting them at one side only causes distortion IMO.
richie00boy said:If you put the pipe into the panel flush to the external side, then use a 3/4 inch roundover bit in a router to round the hole like you would round an edge of a panel.
I just thought it was the right thing to do really. ATM i have a 77L box tuned to 20Hz but the port noise below 25Hz gets quite intrusive.
The port I used is a very thick/stiff roughtly 10mm card tube with internal dia of 79mm (like a mini sonotube)
Because of this noise on my second sub I was going to replace it with a larger diametre smoother pvc tube of about 100mm dia, like the monolith sub uses.
The BK monolith has flared ends!
richie00boy said:By sticking with downfiring you drastically reduce the walking tendency, so push-push is not needed.
I'd say that lack of walking is just a beneficial side effect of push-push... given only 2 woofers i'd build 1 push-push box instead of 2 not push-push...
dave
Hi,Marsh said:........The port I used is a very thick/stiff roughtly 10mm card tube with internal dia of 79mm (like a mini sonotube)
Because of this noise on my second sub I was going to replace it with a larger diametre smoother pvc tube of about 100mm dia, like the monolith sub uses.....
4inch UPVC drain pipe is 102 int. diam. and 110 ext. diam.
- Subwoofers
- Will it ruin the great sound I have?
