CCS-loaded cathoder follower
Hi Giaime,
I am looking for a CCS-loaded cathode follower preamp (e.g. 12B4A, 6EM7 etc.). Could you share your circuit?
Thanks.
T.C. MA
Giaime said:It seems so strange to me. I'm using a CCS-loaded cathode follower in my preamp, unbypassed. It works, so? You don't need to bypass the cathodes of SE output tubes if you use a CCS.
Hi Giaime,
Thanks.
T.C. MA
Hello, you can find all schematics online on my site, in the "preamp" section.
http://www.giaime.altervista.org/
Giaime said:I'm using a CCS-loaded cathode follower in my preamp, unbypassed. It works, so? You don't need to bypass the cathodes of SE output tubes if you use a CCS.
Perfect sense Giaime. A capacitor is a constant voltage device. It would only fight with a constant current source until one caved in.
