Wide version of Classic GR dMar-Ken7.3
Hello,
I've got a pair of Alpair 7.3 drivers, which I was planning to put in the Classic GR dMar-Ken7.3 cabinets. I see that the 7.3 update only appears in the slim and not the wide version. I assume that I could change the internal bracing and place the driver on the ‘side’ and in this way make it a wide version like it’s shown in the previous model. As far as I can see the only difference between the old and the new cabinet is the port length – is that correct?
By the way, if I make a wide version of the Classic GR dMar-Ken7.3, could I then make the vent on the front or the back instead of the side, like it’s done on the Classic GR dMar-Ken10.2? Or perhaps I could replace the square vent with a circular tube?
Thanks and regards,
Søren
Hello,
Thanks and regards,
Søren
well, in Dave's nomenclature, "GR" has so far implied "Golden Ratio" in terms of aspect ratio of dimensions ( i.e. 1.618 / 1 ) - along with mirror imaged off-center driver mounting, so within those constraints external dimensions could be adjusted - turning the boxes on their sides should be no problem
as for ports - provided the CSA and length are retained (or recalculated if necessary) their location could also probably be played with, but the near aperiodic performance of high aspect ratio slot ports and carefully damping enclosure walls are significant contributors to the smooth and extended LF roll-off of the design, so I'd be inclined to keep that
several years ago we did a simple test with a smaller box design - two pairs of enclosures otherwise identical except for the ports - one pair round and the other slots - even though the slots can be slightly more work (but nowhere near as fiddly as magnet nesting holey braces), we've used them almost exclusively since.
Dave could confirm that only the port dimensions (possibly only length) needed revision with the most recent revision to the Alpair7, and whether it applies to both magnet layers.
Thanks for your comments Chris. The thing is that I'd like to have a clean look for the cabinet, i.e. no visible openings, so ideally I would have the port on the back of the cabinet.
Since Dave's updated version of the cabinet has a shorter port, I'm tempted to build a slot coming out on the rear side of the cabinet. I've made a sketchup drawing of my idea and attached it here (shown without back panel for better view).
The port length of the Classic GR dMar-Ken7.3 is 154mm. If I do the port on the rear I can get a length of 142mm, but considering that the last 90 degree angle would become part of the port, I guess I can add 15mm to that, making the total length 157mm, just 3mm longer than the original design.
Does this make any sense, or should I just stick to the orginal version and have the port on the side?
Thanks,
Søren
Thanks,
Søren
I'd ask Dave - he may already have a (few dozen) unreleased sketches along similar lines
frugal-phile™
Joined 2001
I ony found out earlier that i actually had never posted the CGR MK7.3 doc, so i scrambled to get one up. Just now i added the missing wide version.
\The high aspect ratio of the slot vent is a critical part of the design, replace it with a circular vent and the bass will get fat and less controlled.
It is possible to move the vent to the front or back, but to obtain the required length requires making it L-shaped. You have to fit a 154mm long vent into a box that is 120mm deep (135mm if you count the baffle thickness). If you want the vent to dissapear you can rotate the vent shelf as shown in the earlier CGR MK7 doc and fire it out the bottom or top, or you can run the vent shelf parallel to the back and vent out the back, bottom, or top. In that case you will need to increase the gross volume to compensate for the extra pieces that create the width of the vent slot.
dave
But how come the newly added wide version of the CGR MK7.3 has different dimensions than the slim version? They are also different from the earlier CGR MK7, which measured 142mm x 231mm internally, both the wide and the slim version.
If I understand you correctly Dave, then I could make an L-shaped vent, but if the 142mm internal depth is in fact correct, then wouldn't my above suggested drawing work? It's 142mm long, but with the added 15mm after the 90 degree turn I get 157mm, which is only 3mm longer than the correct length of the port.
By the way, and this is just a thought... If the high aspect ratio of the slot vent is critical, could I then have the aspect ratio even higher and make the slot wider but not as high, and in this way keep the cross-sectional area? Would that work?
Thanks for the help.
Søren
frugal-phile™
Joined 2001
Looks like i screwed up somewhere... i was in a hurry putting that together.
142mm internal depth looks like the correct one By my calcs you end up with 158, so if you subtracted add a flair by increaseing the width of the gap by 2mm you'd be OK. You'd need to increase the height enuff to cover the volume added by the extra vent -- the tidy way to do it, is to stretch it all the way across and than add a vent spacer of appropriate width to bring the open bits the same.
You could... you'll still need to adjust cabinet volume
dave
frugal-phile™
Joined 2001
Just did some checking... i really screwed up, neither the slim or wide are optimum, the wide would be right if the vent shelf length was increased to 158mm (173mm total length).
It wouldn't be a dMar-Ken7.3 but a cMar-Ken7.3 so it is a work in progress that escaped.
The slim enclosure also needs a longer vent, and a bit less volume.
dave
Hi Dave,
Thanks for taking the time to look at this. The Soren Edition was exactly what I was looking for! ;)
I'm still confused about the port length though. In the PDF you just linked to there are three different lengths shown.
The wide and slim version with the 'original' slot vent has a length of 160mm (page 1+3). The slim version with 18mm panels has a port length of 173mm (page 2). And finally the new version on page 4 has a port length of 142mm. Aren't these port lengths supposed to be the same?
I suppose that the new version shown on page 4 actually has a longer port due to the L-shape. However, shouldn't the port length then be 147mm? In this way the L-shaped part of the slot would have a with of 10mm, keeping the SCA 2160 sq mm.
/Søren
frugal-phile™
Joined 2001
18mm not done yet and slipped into that doc by mistake. That page should be the 15mm front vent.
fixed the doc... http://p10hifi.net/tlinespeakers/FAL/downloads/CGR-dMar-Ken73-301011.pdf
I had to do some dancing there, as the 15mm wide space is not sufficient to ignore the distance to the back wall and makes the vent a flared L-shape on the inside end. If the space was pushed to just 10mm the vent would be 167mm long, so it needs to be flared to effectively shorten it.
dave
I see. Didn't realize the inside end of the vent would work as a flare. In my case though, with the vent on the rear, I guess I could also run the slot vertically parallel to the back wall, and in this way have the full 167mm length without a flare? Would this be better than the shorter flared vent? I don't get why the non-flared 10mm slot vent should be 167mm instead of 160mm though. Does the higher aspect ratio require a longer vent?
By the way, may I ask what software you use to make these plans? I like the layout.
Thanks,
Søren
Thanks for the illustration. A picture is worth a thousand words :)
I didn't understand the numbers you said, but now I get that you're of course including the diagonal of the 90 degree turns. So if I do the vent along the back wall it would be, as you said, 138mm + (15+7.07)mm = 160.07mm.
Thanks again. Time for me to get building!
Hi Dave,
I had some wood cut up in a shop, but as they didn't charge me for each cut, I decided to have the whole board cut in panels matching the CGR cabinets. In total I now have enough to make three sets of speakers :)
I'm now thinking of getting a pairs of Mark's CHR-70.3 drivers too. Could I put these in to the same enclosure? I haven't build the cabs yet so I could adjust the vent length if that would be needed, but I'd prefer to keep all other dimensions the same. WinISD gives a smooth frequency response if I make the vent 1-2 cm longer compared to your CGR dMar-Ken7.3 design.
What's your thoughts on this?
Thanks,
Søren
