This online generator is useful for illustrating sounds/phases of harmonics.
Anybody know of a downloadable version of this ?.
Additive synthese waveform generator
Dan.
Dan.
Which JJ was it ? They make 3 types of 12ax7 ( ECC83S, ECC803, ECC83MG ) ?
All 4 tubes were EEC83S. So JJ makes 3 style of tubes that will sub for 12AX7?
I wonder if they are designed differently or do they just select the better ones and give them a pricier label.
BillWojo
My amp came with cheap made in China tubes in the preamp.
Harry, what were those? Just a number with no maker's mark?
Dan, the synth is very cool - thanks! It's interesting to play with different fundamentals and the different waveforms. On sine waves, anything above H3 sounds like a distinctly different tone to me. But that's frequency dependent. Go down an octave or 2 from 440 and H3 isn't distinct as a separate tone.
The violin is good to tinker with. Even as little H10 as there is, change it and it very much changes the timbre of the tone.
Harmonic Waveform Generator :: Electronic Measurements
They are all different, 2 short plates and one longplate. See eurotubes.comAll 4 tubes were EEC83S. So JJ makes 3 style of tubes that will sub for 12AX7?
BillWojo
for pictures.
in a production chain all the factors mechanical, the tolerances, the materials, generate some difference, littles or big.
more complicate and delicates are the structure and greater will have differences.
These is common characteristics any hi-fi components.
more precise is your measurement equipment and will you are capable to see the differences.
Shu Guang on the box
The tube simply says 12AU7 CHINA in red letters
Is your amp PP with one tube doing both channel's amplifications and the other for inverters or is each tube dedicated to just one channel for both jobs?
My amp it the Elekit TU-8200
Single ended
One tube per channel
Wheewww! I see. With that being a 2 stage driver it's not a suprise you got a different, better, result from another 12AU7. Good thing you tried that.
Surprisingly different change.
I was mostly changing them because I wanted a higher quality (aka reliable) tube.
i made similar one Volume.zip - Google DriveThis online generator is useful for illustrating sounds/phases of harmonics.
Dan.
only 9th harmonic, and no phase shift (yet)
in future i can update it , if there is demand
- Tubes / Valves
- Why do tubes of various brands sound differently?
