Which replacement transistor for Sanken C3856/A1492?
Haha, this amp is very frustrating!
The main output transistors are the 2SA1492 and 2SC3856, which are made by Sanken and are the original parts. For the drivers, I couldn't find the original parts, but I found equivalents which seem to work no problem, they are 2SA968 (replaces 2SA1659A) and 2SC2238 (replaces 2sc4370a), both made by KEC, which is the manufacturer of the original drivers. I believe Toshiba also made them, and there may be a newer equivalent from them if you can't find them either.
I don't know if there are any equivalents for the original output transistors, but it's possible. If you can't find any of these, you may have to buy the parts from another country. Not sure if they ship overseas, but the company I bought some from www.bdent.com (in the US), had fair prices and seems to sell legitimate parts.
rkc7 said:
The schematic is too large to attach to the board, so I uploaded it to a schematic website. You can get it here:
http://www.eserviceinfo.com/downloadsm/20235/Samson_S1000.html
Looks to me like a fairly (and unnecessarily) complicated class-AB amplifier. Have you ever tried to reduce distortion by placing an electrolyte in parallel with an MKT-cap between the drains of Q109 and Q110?
Can't say I'm familiar enough with amplifier circuit operation to have even thought of that, haha. If I'm ever feeling adventurous, I'll give it a try.
jacco vermeulen said:
2SA1294/2SC3263, affordable and can be bought in any corner of the big peanut.
They're actually twice as good as the originals: SOAR has 2 times higher current for DC and 5 times higher for 100mS.
1 Dollar the Watt is value for money, imo.
Can't really find many places that carry them using Google... only Profusionplc.com has it listed as a Sanken part, but shipping charges would be kinda high for me being in the US ($50, almost doubling the cost of replacing all outputs!) but good for those in Europe, I suppose.
After a hard fight with both channels my Samson S1000 works. I've got the best results with 2SA1516 and 2SC3907 powertransistors. But now i need to re-adjust the idle settings for each channel. RKC7, do you got these? Or is it possible that you can measure this with you're own amplifier? Thank you anyway! (And still this is a crappy amp!:D :D :smash: :smash:)
Do you want it run for any amount of time?
The values seemed to drop after turning it off and on a few times.
The last reading for my first channel was 10.6mV, second channel was 9.6mV. That was across the outputs of the pair nearest to the front of the amp on both channels. Seems ch 2 was consistently lower than ch 1, does that suggest the amp needs bias set or is that an acceptable difference?
Joined 2006
rkc7 said:
I'm looking for some replacement transistors for Sanken (2S)C3586 and (2S)A1492, can't seem to find them anywhere.
Mouser lists NTE2328/NTE2329 as equivalent replacements and I saw on another post on here about someone using Toshiba 2SC5200/2SA1943 as replacements.
Which would be a better match and/or sound better, etc... these would be used in a Samson S1000 power amplifier.
The Toshibas are much cheaper at $2.25 each while the NTEs are $6.12 and $7.25. If the Toshibas would work, they seem to be the better deal.
Also, anyone know where I can find schematics/service manual for the Samson S1000?
Hi
I have a DENON POA 6600 A that needs output transistor replacement.
The original parts are Sanken 2SC3856 and 2SA1492.
After reading all the posts, I believe that in the DENON case I should not try any replacement and stick to the original ones (This amp has a optical bias setup circuit based on very tight tolerances).
Can you help me find some ?
Best Regards
Ricardo
Joined 2006
Hi
I have a similar problem trying to find alternatives to 2SA1492 / 2SC3856.
Fortunatelly and thanks to you I now know of two possible alternatives:
Alternative 1 - 2SA1294 / 2SC3263
Alternative 2 - 2SA1386 / 2SC3519/A
Can you please advise as I am not at ease with the datashhets ?
I want the maximum speed even if I loose some power (that I do not need).
Best Regards
Ricardo
Hello Rob. You are the next victim! When will the pain stop??!! ;)
The answer on your question:
I didn't know for sure, but i thought i used the 2SA1294 and 2SC3263. The 2SC3856 and 2SA1492 where also used in my Yamaha P1600 amplifier, i replaced this with the 1294 and 3263 and this works fine! If you need, i've got an service manual of this amplifier.
Hey im also looking for this Transistor C3856 03Y Sankin. I need them for a sony stereo receiver. I want to replace all four and a couple of resistors. If you already found them let me know where so i can get them. Thanks in advance!
