Here are the settings I used for channel 2:
- volt/div = 5m (selector below this knob set to DC)
- Var/Unical = off
- Vert mode = channel 2
- Time/Div & Delay time = 0.02us
- horizontal display = A
- A Trigger Level = 0
- Source = Ch2
- Coupling = DC
- Holdoff = Normal
- Trig Mode = Auto
Placing one end of the wire inside the centre of the input plug and the other end on the cal bridge(and after focusing and positioning the wave) I do get a strange ripple wave on the screen, it may just be the wire that's picking up interference somewhere. Anyways the trigger lamp does come on. The same sort of thing happens with channel 1 except that the A trigger level doesn't behave the same way, I have to turn that knob towards the right side inorder to get the trigger lamp on and view a ripple waveform on the screen.
Does all this mean the scope is working properly?
- Var/Unical = off
- Source = Ch2
- Coupling = DC
- Holdoff = Normal
- Trig Mode = Auto
As Macboy states 0.05V/DIV I mistook that for the mV reading so now I've set it to 50m and the horizontal to 0.2mS and here is a photo of what's on the screen:
13042013510 | Flickr - Photo Sharing!
That's looking better! Can't tell if that is the peak or the trough of the waveform though.
Adjust the intensity and focus so the trace isn't so hot (unless that was just for the photograph). Then raise the Volts/Div to try and get a full wavelength on the screen. I wouldn't worry too much about seeing the rising and falling edges at this point. When you get a full wavelength, you can use the vertical and horizontal Position knobs to align it with the graticule. The waveform should measure the calibration frequency and voltage.
I raised the volt/div to .2 and this is what I'm getting:
13042013511 | Flickr - Photo Sharing!
It seems as though the rise and fall are not visible, is this normal?
If so, I can be sure that I've got a working scope?
thanks
thanks
At 0.2 volts/div the 300mV signal should be 1.5 divisions... that looks good. At 0.2ms the 1kHz signal should be 5 divisions... that looks good.If so, I can be sure that I've got a working scope?
The sure level has gone way way way up. The A channel should do the same with these settings.
Finally managed to take the cover off my scope, here are some photos:
17042013518 | Flickr - Photo Sharing!
17042013520 | Flickr - Photo Sharing!
17042013521 | Flickr - Photo Sharing!
17042013519 | Flickr - Photo Sharing!
And here is a photo of what was rattling around inside the scope:
17042013522 | Flickr - Photo Sharing!
I had a good look but I couldn't find anything broken, does anyone happen to know where these plastic bits may come from?
thanks
thanks
Just got my P6063B probe and this is what I'm getting on the scope:
18042013523 | Flickr - Photo Sharing!
How come the rise and fall are still missing? They're just barely visible on the angles of the horizontal lines... is this normal?
thanks
thanks
I think I have the chance to see what my scope can do. I've got a bassman clone on the bench that tends to whistle at high volumes, the bright channel, treble and presence seem to be the main victims, though I think it may just be where I placed the NFB wire. Anyways I'd just like to start using my scope on real equipment... the question is... how?
thanks
thanks
thanks
If you want to see the rise or fall, just crank the timebase to a higher speed. That will spread the signal out, horizontally. Adjust the horiz position or trigger level until the potion you want is positioned where you want it.
- Tubes / Valves
- Which probes for my first scope?
