I'm searching 6U 19" rack case. Best would be plain case made of steel. Front panel can be aluminium.
Does anyone have a link?
JoRed
Rackmounts.com Ordered from them a bunch of times with very good service and products. I mostly get Middle Atlantic stuff. Not the cheapest but good stuff.
Now, you say "rack case". Do you really mean a 6U chassis for rack mount? Totally different animal. A rack case to me means a ROAD case for putting rack gear into it and take it on the road.
A typical chassis is p/n DF1334 which I built my pre amp into it. Middle Atlantic the maker.
Thanks this is exactly what I was searching thank you very much.
Well, whatcha building? Don't keep us all in suspense!!!
Curiosity killed the cat !
But u where so help full that I have to tell u.
I'm building a preamp for the reggae sound systems.
Features :
2 class A phono deck in switchable to line in with 2 FX send
1 line in with 2 FX send
2 mic in with semi parametric EQ with 2 FX send
10 band graphic EQ
2 semi parametric for modulating bass and mids
4 way crossover phase aligned
All line, mics and FX in and all outputs are balanced
Only using the best film caps
BB and That opamps
Metal pots
Neutrik connections
All in all I hoping it will be an HIFI preamp.
That's it
Features :
10 band graphic EQ
BB and That opamps
Metal pots
Neutrik connections
That's it
As requested here are some images of the beast
I tested it in session and the sound is really good. Plenty of details in music, great mike preamp, crossover very tight , deeeeep bass (measured down to 20Hz from speakers). Im very satisfied.
Thanks again to you jrockhead for your contribution.
- Design & Build
- Parts
- Where to buy 6U 19" plain rack case
