While I haven't built Pete Millet's Sound card measurement interface, I did pick up some of the MuRata DC-DC converters from DK which he used in his design. I pointed out on that thread that the NDTD2415C which I have (converts the 32V which I have in my Pioneer SX-838 to +/- 15VDC) benefits from a choke on the front end. While they have 12uH in the product data sheet, I picked up a little 12mH choke from a discarded switch mode power supply in the inductor junk box. Here's the before and after:
BEFORE
AFTER:
Load is 40mA on each side. The A-Wtd noise on the bottom is 2.6uV. Note that the scale on the top chart is 50mV vertical, the bottom 20mV.
BEFORE
AFTER:
What's the purpose of this thread?
I don't know. What's the purpose of the F5 thread?
Thanks for the info, very interesting. My first idea was to put filters on the outputs but this seems to work very well so I may not need to do this (I only have inductors with 3 Ohms resistance so would lose some voltage).
I still wonder whether it would bring any benefit to put some shielding around the PS components and/or move it to a separate board.
Just showing the implementation of the little Murata DC-DC converters -- with bipolar output. You can take 5VDC out of your USB jack and get relatively clean +/-15VDC for running opamps without bending yourself into a pretzel with a single supply configuration. A lot of Japanese receivers I've modded have a unipolar supply and use a bunch of electrolytics for coupling. This is easier.
12mH is not what Murata had recommended, and indeed it sucks a few mA more than the non-choke implemented supply...I was very surprised that the noise was as low as it was. Here's my implementation.
Jack,
Can you point me to the sound card measurement interface?
Thanks,
Ken
I've been using a similar DC-DC converter for the last couple of years and find them indispensable. They are compact, reasonably well regulated, and the small ripple on the output cleans up nice with a simple CLC filter.
Mine are BWR-15/330-D12A which take a 9-18VDC input. I bought quite a few of them off some telecom dude for about $10 each; they sell for almost $90 new.
Digi-Key - 811-1723-5-ND (Manufacturer - BWR-15/330-D12A-C)
I consider them my little black bars of gold.
I tried using some lower ESR electrolytics and put them on the inputs and outputs of the 24-> +/- 15V converter (should heed my own advice and read the datasheet!) -- or you can bypass with a 100nF ceramic, or use a tantalum. The noise on the input rail is down in the uVolts.
With or without the 12mH choke that you included in your earlier measurement? I'm putting together Pete's design, and wondering if I should find a place to mount a small choke on the input.I tried using some lower ESR electrolytics and put them on the inputs and outputs of the 24-> +/- 15V converter (should heed my own advice and read the datasheet!) -- or you can bypass with a 100nF ceramic, or use a tantalum. The noise on the input rail is down in the uVolts.
I'm also putting together Pete's from end and that was my thought exactly, is a small choke the way to go and, if so, what part #?
thanks,
Andrew
Whoops that didn't type right! I'll try again....
I'm also putting together Pete's SC interface and was basically wondering the same thing? Do I add a choke and, if so, what one, can anyone recommend a part #?
thanks,
Andrew
Well, I've ordered a small 150µH choke (rated for 1.1A), and depending on how the board gets mounted in the chassis, I plan on adding it to the input of the unit...right before the 470µf 16V cap.
- Power Supplies
- When you need +/- 15VDC and have only one pole
