Hello
I am a new member. I have just recently become interested in Tube Hi-Fi . I have built several tube guitar amps, so I know the basics but still consider myself a novice.
I would like to build a good sounding stereo amplifier. I would like to use 6l6gc`s and 12ax7`s or 12au7`s because of the availibility of these tubes. I have a working Heathkit aa-50 integrated amp for a parts donor.
What I am looking for is advice. What is a good design for me to build. Are there any amplifiers that use 6l6`s that are real "shinning stars"? Somthing that delivers good performance and will give years of listening enjoyment.
Glenn
Glenn
Try http://gabevee.tripod.com . Gabe has a 6L6GC SE kit that he sells, but go to the index at the bottom of the page and a bunch of stuff will pop up. There is an article on a SE amp using the 6L6GC as well as others. Good luck.
6L6
you can find a schematics for the 6L6 on my site, last week i put on a curious "Parallel output push pull" using these tubes, but unfortunately needs a special OT
ciao
Filippo
www.audiofanatic.it
ciao
Filippo
www.audiofanatic.it
Uncle Ned has a whole bunch of great schematics on his site at:
http://www.triodeelectronics.com
I am sure you will find some good ones using 6L6's. You can also take just about any p-p amp and substitute the output tubes with the 6L6, just considering the primary impedance of the output transformer. You can use upwards of 400 volts on these tubes.
Hope this helps.
Hope this helps.
hint
6L6, yes of course, Glenn
i have ever build a 6L6 rusian(triode connected) class A pushpull, drive by triode 6sN7 rusian as a split phase shif, and the gain stage using triode 6sL7 with a tubes rectifier 5U4 with a home build power transformer and output transformer, and this amplifier tone bright, its suitable to reproduce a guitar sound like ibanez, not a fat sound it not so suitable for bluesy sound gibson, try for a pentode or tetrode connected for a bluesy sound, it needs more power
just want to remind you
build an amp for guitar different way compare to build an amp for high end sound system
triode (300b,vt52,211..), pure class a, direct heat tubes, low harmonic distortion, low impedance, ussually suitable for high end
pentode (ef86,el34,6l6,6550..), high 2nd harmonic distortion, overloaded(un matched load, or speaker impedance), ussually suitable for a guitar amplifier
best amp in best purpose
regard
regard
Sorry, got to question the above post.
By that definition the Quad II is a great guitar amp because it uses 2 x EF86 + 2 x KT66 (variation on 6L6). I some how think that many people who use this amp would argue with you, as would any ST70 & Citation users.
Mind you I'm not anti DHT, as I'm in the process of getting the bits together for a 300b amp.
kt66
>lilolee
it's a nice having your correction on my statement, yes of course pentode is just the global statement for a great result in guitar amps.
kt66 is the variation in 6l6 but it is known better in a high end amplifier, and also kt88
we have a global line and also we have a special line for exception : and for example is kt66,kt88 etc tell me if you know the others ?
>lilolee
After I posted my reply I did some searching around. I wish I had bookmarked it but I came across a site that made 300b guitar amps!!
A fine example of cross pollenation, because IIRC it used a 6L6 as the driver.
When it comes down to it I really feel it is horses for courses. I wouldn't use a 2A3 to drive my Maggies, but maybe a 40watt 6L6 or 100watt KT88 might be a bit OTT.
Happy listening
Lee
Happy listening
Lee
- Tubes / Valves
- Whats a good 6L6GC Stereo Amp Project
