Whats a Good 6L6 circuit?
EC8010 said:
I've been searching desperately to find the article (I think it was Hafler), but I just can't seem to find it I have a feeling that the coupling capacitors were made quite a bit bigger, perhaps 1.5uF.
Hafler and Keroes, Audio Engineering, reprinted in Audio Anthology v2, "Ultra-Linear Operation of the Williamson Amplifier".
from Hafler and Keroes
The low frequency time constants of the original circuit's interstage coupling networks were the same for both such networks. This is not particularly desirable in a feedback amplifier... Increasing one pair of coupling capacitors from 0.05uF to 0.25uF... increases the low frequency stability margin at nominal increase in cost.
Hacknet
Andy's suggested circuit is much better than a Williamson. That is if you want to build a modern sounding amp and not just something of historical value.
Going as far back as the sixties amp builders noticed the Williamson plays better in mono than stereo. Lots of NFB keeps the sound strictly in the speakers, kills dynamics and soundstaging and together with the excessively repetitive use of 6SN7 produces cold and boring (for a tube amp) mids.
diyAudio Senior Member
Joined 2002
As an example:
I have a PP 2A3 amp that uses only local FB, no global loop whatsoever...
The soundstage that little amp can throw is little short of amazing.
With any decent recording you can plunk the speakers down, even only 4-5 foot apart, you just can't tell the sound comes from those speakers.
That's not to say the amp is perfect, it isn't.
For what it cost me however it's a joy to listen to.
Cheers,;)
Hi Frank, i've been wanting to make a PP 2A3 and been contemplating on the JE Labs PP 2A3. However, I want to try one of yours. Is that at all possible? Share the schematic or is this a commercial amp?
That's not to say the amp is perfect, it isn't. For what it cost me however it's a joy to listen to.>
That's exactly my response to taking off the global feedback loop - joy! The sound just makes you like it - happy pills. Haven't got a clue how this effect measures, but I was just grinning when I heard the sound without feedback. If I'm reading the language correctly, others seem to have a similar response. Not to say that others don't grin when they add feedback - I'm sure this happens too.
Joined 2002
ArnoldC,
It's not a commercial amp but I still have to draw a schematic.
I'll post it when it's done.
In the mean time, thamks for the confidence you put in me.;)
