For my single ended 6550 amp I am going to use cathode bias of the 6550 power tubes. My Av is 325v and the G2 voltage is 275v. Your input is most appreciated. cheers, 808
What do you want your plate Pd to be? 30W? Do you know the formula for finding cathode current?
OK, I think I have some 390 ohm. I dunno about the wattage . I might have to double around a 800 ohm 2 watt.390 Ohms, 5W minimum.
From what I have gleaned about the subject you would want to have the tube dissipate close to max. That is why I picked about 90% of max. I was using v=ir to calculate the current dissipated by the resistor.What do you want your plate Pd to be? 30W? Do you know the formula for finding cathode current?
My first resistor was 470 ohm but that was way to cold. If I recall that was about 60ma cathode current. I wanted to know what other builders had previously used in successful amps. cheers.
- Tubes / Valves
- What value for the bias resistor of a SE 6550?
