What tool to cut baffle holes?
loninappleton said:
What's a pincushion?
Rotozip-type tool has real high speed and I steadied it as best
I could.
A word of caution: Many cheap router bits aren't rated for the rotozip's speed. I don't like the idea of a bit flying apart. I know it doesn't spin nearly as fast under load, but I only use bits rated to 20,000 rpm. Also, the real weakness isn't the rotozip jigs or any other, its the tool's stock base. I'd imagine it would work much better with the router base attachment.
AFAIK, 'pincushion' refers to drivers shaped like this:
http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=295-300
You can't use a circle jig to cut that recess.
pj
Henkjan said:
there are plenty DIY circle jigs around
like here (it'sin german)
http://www.uibel.net/bauvor/bv_tutorials/fraeszirkel/d_fz.html
That looks like a good shop built system for a small router or rototool.
The small rototool or laminate trim variations as small routers
(unlike the Trend or that Bosch shown) don't all have base plate machining to attach a jig with screws. Routers don't come around for sale as used very often. The Bosch shown will have better availability than the Trend. I haven't seen or noticed one just like that.
Re: What tool for Cutter baffle holes
kvk said:
I supposed a Jasper Jig is probably the best tool for routing baffle holes for drivers but it's about $40 which is a fair amount if you are only building one pair of speakers.
Are there any cheaper options? Does someone make something like a cheapo adjustable jig for routers?
I do have a router and bits already.
One pair...right ;)
Once you get into DIY, just doing one is hard :D
