What players use the VAM1250
Update time... its taken me a bit more time than planned, I tried to lift a 40kg power amp, the amp won and I've ended up in bed for a week with a nasty back strain... Anyway, with the help of jpk73, I made direct contact with the eBay Marketplace seller he mentioned, bought a drive, fitted it tonight... and it sounds gorgeous! Thanks again to jpk73 for his pointer :)
Reactions: 1 user
One additional question/request... not too sure I should post it here, but does anybody have a CD tray from one of these VAM1250/VAL1250's? Just the single tray, nothing else. In removing the clear perspex fascia on the front of the old drive in my Maestro, I damaged the front of the tray. As I had a new drive to fit, it wouldn't normally be a problem, but I've managed to get the faulty VAM drive in a Philips CDR775 working, but using the damaged tray from the Maestro drive. I know the disk tray is hidden behind a flap on the CDR775, but it'd be nice for it to look good...
Hi Orbscure
I was wondering - did you resolve this "no disc" issue?
I too am thinking of buying a VAM1250 from this Seller.
Not sure if its new or been taken from an old CD player - but am tempted to order one for my CDX2.
...and JPK 73 - I take it that yours is working okay still?
Chris1999
I successfully tested the replacement mech I got from the seller in Germany: it's an original VAM1250 by Philips, he has it from a (closed) workshop stock, I wired it in and it played fine in my Naim CDS3 (the Naim is said to perform a special test routine and reject the drive unless specs are spot on). Not cheap, but I think worth. He has some more left, so if you want to buy one from him you can contact him here.
good advice
https://www.ebay-kleinanzeigen.de/s...fuer-naim-cd5i-cd5x-cd5xs/2364011255-172-7547
I think, NOS Philips mechanism, made in Japan.
Laser head only isn't always cheaper - as long as it is Philips NOS from Japan - go to
http://www.ersatzteil.justone-schnepel.de/html/philips-6_lasereinheit.html
https://www.donberg.de/descript/v/vam_1250.htm
https://quickcycle.co.uk/products/softone-model-3-cd-laser-pickup-diode
Laser head from CD-pro2 resp. VAM1254 seems to be the same - go to
https://encosystems.net/product-category/optical-pick-up-units-opus/
most expensive offer - maybe yet better than those of VAM1250 mechanism
Description of CD-pro2 resp. VAM1254 (check also attached files):
https://web.archive.org/web/2009010...com/products/modules/cd/cdpro2lf/cdpro2lf.htm
VAL1250 (loader completely):
http://www.ersatzteil.justone-schnepel.de/html/vam1250_val1250_vae1250.html
in this thread is to find an image of various packages (of other Philips laser units - not VAM1250 head), which I have save here:
https://www.audiostereo.pl/topic/45746-napęd-philips-vam1250-gdzie-kupić/
It's probably about distinguishing which offers are original parts and which are cheap not reliable replicas.
Basically this should be the case with all packages of Philips parts - also with the VAM1250 head
Unfortunately I don't understand the Polish language.
additional suppliers of high quality parts
https://wurlitzer-shop.de/en/produkt-schlagwort/wurlitzer-cd-player/?products-per-page=all
https://www.tentlabs.com
P.S.: obviously there are at least two variants of laser hologram diode (Sharp) in use on this laser head - go to the last images. Which of them is most reliable and have long live character ?
  • cdpro2lfVAMspec11.pdf
  • Schema VAM1254-21 GH6C005B3BA TZA1022.pdf
  • VAM125x head schema TZA1022 (4).pdf
  • cdpro2mVAUspec11.pdf
  • CD pro2 user manual.pdf
  • Original-VAM1250-CDM1250-f-r-Philips-CD-Optical-Pickup-Kopf-VAM-1250-VAM-1250.jpg
Reactions: 1 user
