Hope this helps.
head_spaz said:An externally hosted image should be here but it was not working when we last tested it.
Hope this helps.
should know schematics but newbie here. what does it mean in practical terms?
gychang
the parallel combination conducts in both directions.
It shines a different colour when positive or negative. eg on the output of a 555 timer if the LED is returned to a mid supply voltage and the timer output is high, the LED is one colour and when output goes low the LED changes colour.
The serial pair with centre tap operates by taking the centre tap to a common voltage. Drive either LED (to the same +ve polarity) to see a choice of colour or drive both and get a colour mix.
