I'm trying to read a book about servicing audio gear, and the author keeps using the slang word "leaky" when describing the condition of transistors, IC's, diodes, triacs, etc... Does he mean that they are leaking current when they shouldn't be? He also says things like "a burnt resistor could be the result of a leaky transistor or IC"
thanks, from Steve
thanks, from Steve
A transistor can develop "leaks" between any (or all) pins.
If the transistor begins to "leak" current between the collector and the base, the transistor will self-bias itself on. If the "leak" is between the emitter and the base, it will be more difficult to drive into conduction.
Worse case is a leak between collector and emitter. At that point, you have a wire rather than a transistor.
Normally leaking occurs across reverse biased junctions, like leakage currrent across the C-B diode junction, leading to base current, leading to collector-emitter current. If you reverse-bias the B-E junction, you will see a sudden jump in (leakage) current at around 7V. That is why you can use a reversed B-E as a zener.
Jan Didden
Jan Didden
peranders said:[snip]....damaged by age, overload (secondary breakdown), ESD etc.
P-A, are you talking about yourself??
Jan Didden
- Analogue Source
- what is a 'leaky' transistor?
