So only resistance matters and impedance is imaginary?
Extreme_Boky I was going to PM this to you but it seems you dont accept PMs hopefully it's not because of the opponents of the subject of this post........
Do you have a source for that picture of you posted on the second page of the thread "What difference does the quality of a digital interconnect make?" of the Silver Ribbon drawn between thicker silver wire center pins? or is that just a pic of the cross section of some interconnect product? I've been looking at silver plated occ copper but I think just reading your posts you've made me a convert to pure silver with internal hookup wire in superior geometry ribbon format........ TY you took me up a level more than I expected in studying wire. I learned so much today. I found a page which I think is the ultimate goal of electric design.
6moons audio reviews: PSC Audio AG Monolith
Monocrystal monolith design. MonoCrystal PCB. Silicon Chip is monocrystal no? OCC monocrystal ribbon wire....with shielding? All audio ribbons non trace direct to silver chip lead. Sata cable ribbon 2 sets differential pair shielded to ground pins. Burson discrete component design? I'm stilll a noob, but I'm getting the lay of the land.....
P.S. Computer weenie digital infallibility(in latin means not deceive aka papal infallibility) is a disease distracting from quantum physics common sense(information entropy). Every detail in the universe matters and they all influence each other. I have been fighting computer weenies in ##hardware chan freenode net on irc for years. It started with metallurgical discussions on wires and ended up in DVI HDMI infallibility ban for me. Which I can now prove DVI and HDMI are not not infallible as proven by 2560x1440 120hz Korean monitor signal artifacting tested across multiple DVI cables because 660mhz pixel clock is out of avg cable tested specs. 600MB/sx8 sata 3 cable? Cat6 600mhz Belden cable? Digital is not infallible and all cables are subject to analog limits. If it works better in extreme situations(shielding negated) its just a better wire overall because of superior geometry(even of the crystal grains, atoms)........
Switching from a Sata 2 unshielded cable I was having problems with Sata 3 shielded(now trying to source silver multicore cable wire with decent individual shields I picked up from another thread on this forum) noticed improvement in OS response(this is impossible to the believer of digital infallibility it either works or it doesnt there is no intermittence bug and interference doesn't exist... digital eliminates it because its a superior workaround to analog failures in telecommunications(cardas)).
I don't think I argued it never matters (nobody here did) but that there are cases where it is far less important because the transmission system itself is very robust, S/PDIF being one example.
Real high speed databusses like HD-SDI, DVI, HDMI, SATA need a well matched transmission line, no arguing about that, altough these standards employ tricks like EQ on the (differential) datalines that really help with keeping the signal integrity, this is all 100% analog transmission, carrying digital information...
More to the point, spdif if done right has a really slow edge rate compared to something like HD-SDI (1.55Gb/s) or sata, and the edge rate determines the smallest feature that needs to be considered as a transmission line. For spdif this is always larger then any of the likely connectors, so even a connector that is very wrong (Phono plug) will do just fine.
If you are genuinely hearing differences between cables, then I would be giving the clock recovery circuits, pll loop bandwidth and lock range the hairy eyeball, doing it really right means locking a low phase noise VCXO to the recovered sclk with a slow loop filter (Above loop filter cutoff you get the PN from the VCXO, below you get the PN coming down the wire). Note that low PN implies a narrow tuning range on the VCXO.
The studio gear design cats have a simple way to design kit to make the gear insensitive to jitter: stick an asrc between the line rx and the DAC! Modern asrc chips have better performance then the eventual DAC, and use a delay locked loop with a small buffer in the rate estimator so that a modest amount of jitter gets efficiently filtered without interfering with rate estimate.
We are increasingly seeing this in boat ADCs and DACs used in studios as it pretty much just works.
It has its limits (Which are easily met) but is very effective as a local rock on the converter board will always have lower phase noise then a pll recovered clock.
Regards, Dan.
Regards, Dan.
When I see incoming 'quantum' in any context apart from physics, chemistry and (possibly) computing I switch on my nonsense shield.SY said:Rule of thumb: as soon as you see "quantum" in an audio context, you're dealing with nonsense.
hmm, I used cheap RGB6 cable with 70% aluminum shield and compression rca jacks for my 25 foot digital cable run from my TV to my ancient Yamaha RX-V992 amp.
No noise, works great.
That cable is laying right with L/R & Center speaker cable runs and the last 4 feet it passes a wall outlet, with a power strip where the computer, monitor, 12v light and stereo gear all meet.
Quite often people tend to over think stuff. If it was complicated it would have never became a standard.
The rise time of the spdif signal will be constant for all clock rates as it is not dependent on the clock rate but on the driver used, unless a circuit switches drivers depending on the bit rate which is very unlikely.
NOTE: The edge rate is faster than the specification as the specification is the worst case allowable rise time.
A 74AHC04 has a specified worst case rise/fall time of less than or equal to 3ns (NXP Datasheet 15, 50pf load full temp range).
A 74VHC14 (ST Micro) shows the same specifications.
In reality the rise/fall time is closer to 1ns and probably even less since our applications will not operate any where near the allowed temperature extremes.
A good rule of thumb would be to use 500ps as the rise/fall time. Most circuits I've seen posted used a 74AHC04, 74VHC14, or similar driver.
This is at the driver pin, not at the output connector.
Sorry, I just assumed your previous post was a spoof. Perhaps this one is too? That will save me the bother of trying to extract and then correct information from the first and last sentences. The middle sentence, by comparison, is actually true!ColdFlo said:So if resistance decreases amplitude which will then have to be amplified for volume you will lose signal integrity. Resistance turns the energy of electrons mainly into heat. Seems to me that quantum information is strongly "correlated" to audio information.
Dan, do you see this done on HD video lines, too? Or is it not cost effective. I don't know what's in the HD-SDI boxes I use, I know they just work!The studio gear design cats have a simple way to design kit to make the gear insensitive to jitter: stick an asrc between the line rx and the DAC!
Classical ASRC at a HD-SDI bitrate would be hard, for video we usually work in terms of entire fields (or frames, depends) rather then lines or pixels.....
Besides the only places small amounts of jitter matter are when the device on the end of the link is a badly designed AD or DA converter and you are using a self clocked link, otherwise as long as the eye pattern is ok there is no need to worry.
SDI line extenders usually just use a pll to regenerate the clocks and then a transmitter to put reclocked data onto the output, they are usually fairly dumb.
SDI is kind of fun to play with if you have a reasonably serious fpga dev kit.
Regards, Dan.
Regards, Dan.
Hmmm ... a bit vicious,When I see incoming 'quantum' in any context apart from physics, chemistry and (possibly) computing I switch on my nonsense shield.
Well!!!!!!!!
Some interesting posts, considering one of the first things put up were links to the likes of Howard Johnson and Eric Bogatin, but obviously you can point an audiophile to knowledge, etc etc.
Digital signal transfer, signal integrity and EMC are all well studied phenomena, we don't even have to make stuff up there is so much info out there regarding it, why do more silly myths and BS have to be created...
I second DF96, when quantum is mentioned in relation to audio sound reproduction you know a big barrel of BS is heading towards you at a very fast rate....
For the silver supporters, lots of hot air but NO CONTENT, how does silver improve digital signal transmission...
Hmmm ... a bit vicious,... I note a category in Wikipedia for such: Category:Quantum electronics - Wikipedia, the free encyclopedia, which has 'real' things in it ...
umm, I dont think that page says what you think it does
Sorry, obviously a poor attempt to point out that that some others are not so averse to associating the word "quantum" with the word "electronics",
In other words, there is a whole variety of electrical phenomena, linked to on that page, where the behaviour is considered to have quantum characteristcs ...
Some confusion there.
RCA is not 50R, or anything in particular.
Impedance controlled connectors (50R for instruments and wireless transmission, 75R for video) are built to the correct mechanical dimensions and dielectric parameters to meet the impedance specs. Ditto with coaxial cables.
RCAs were "designed" as a cheap and cheerful audio connector, not needing impedance matching. They happened to be close to 75R (but that would depend on who built them) so got used for video connections in consumer gear as well.
The Only Thing Worse Than Being Talked About... Is Not Being Talked About....
Dan.
Yes, IIRC Jocko had words to say about the importance of drive and termination impedances, and stronger words about particular cable length in relation to cable propagation velocity...think arrival times of multiple reflections at the receiving end.........Edit: How to implement S/Pdif have been beaten to death several times no need to discuss it in this thread just look up almost any old post by "jocko homo"
Dan.
That seems to be mainly physics or applications of physics, so genuine quantum stuff. Note that real physics is amazing enough, so why do people have to invent stories? I know, it's because they don't understand the real stuff.fas42 said:I note a category in Wikipedia for such:
RCA is not 50R. It is not constant impedance at all. However it may, at sufficiently low frequencies, be a rough approximation to 50R. To make it look more like a rough (even rougher!) approximation to 75R you would need to add a little inductance in series with the centre pin. Some people may do this accidentally with their wiring.Triodethom said:A some what late question how does one transform a 50 ohm connector (rca type) in to a 75 ohm connector ? Side note why was 75 ohm or 120 ohm chosen for the transmission line then a 50ohm connector used ?
75R, as has already been said, is the standard for video and the same drivers can be used for digital audio.
120R can be fairly easily obtained in twisted pair - I think. Generally, twin cables have higher impedance than coax because there is less capacitance between the conductors.
- Digital Source
- What difference does the quality of a digital interconnect make?
