arnoldc said:I was able to finally replace the LED with 120R bypassed with 100uF.
When I measured the voltage at the 396A cathode, it now reads 1.6V.
I plugged it in to my system, but seconds after it played music, the right channel emitted a popping noise, and the 03D is blinking in symphony. I immediately turned it off.
Any thoughts?
so:
1v6/120R=13mA per input tube
(400V-150V)/5600 = 44,6mA
44,6-2 x 13 =~ 18mA through OD tube
0D3 have range of 5 to 40mA , so middle is 22,5mA , and that must be minimum current through it;
to be safer - choose 25mA through.......
so - overall current is 25+2x13 = 51mA
(400-150)/51mA = 4K9 ........ instead 5K6 ........... use 4K7 !!
in your boots -I'll still use one 0D3 per one input tube
resistor is rated 20watts, was thinking along the same lines too..
When I see two non staggered LC resonators in a row, I worry. I'm not currently on a computer with PSUD2, but if you haven't already, you might want to run a sim, looking at behavior after a current step.
Without regard to hum, it might be interesting to replace one of the chokes with a resistor and see if the problem changes.
I heard you but I THOUGHT I will be drawing the same current with the change from LED to resistor. Will change it.Zen Mod said:(400-150)/51mA = 4K9 ........ instead 5K6 ........... use 4K7 !!
Because of the layout of the chassis I can only have one 0D3. Or I can dump the 5AR4 and use SS on the rectifier and put two 0D3.
poobah said:Divide and conquer...
Move the OD3 and the 396 from the left channel to the right.
I only have one 0D3. In fact I changed to 2C51 (both input tubes) and it still happens.
Ok, I failed to change the 0D3Tony said:well, like all tube equipment, first thing you do is to replace the regulator tube and or input tube to see if things improve....
Hi SY, my rectifier is hybrid, i.e., 5AR4 + FR107. When I simulated with PSUD, I used 5AR4 bridge...SY said:When I see two non staggered LC resonators in a row, I worry. I'm not currently on a computer with PSUD2, but if you haven't already, you might want to run a sim, looking at behavior after a current step.
Will check it out again.
arnoldc said:I plugged it in to my system, but seconds after it played music, the right channel emitted a popping noise, and the 03D is blinking in symphony. I immediately turned it off.
Any thoughts?
VR tube + parallel capacitor= OSCILLATOR! These puppies aren't like Zeners where you can just wire in a huge capacitor to kill the noise. Any sort of spark, arc, glow discharge has a negative resistance characteristic. That's just fine and dandy if you want an oscillator, but here you don't.
Either use the VR tube as part of an active regulator, or add the noise filter after the VR tube, but don't wire a capacitor across the VR.
Ok, ok. A previous recommendation suggested one, so I had a 0.05uF film across. Will remove it.
Caps up to 0.1uF are fine, and recommended. Larger than that is a problem.
john! nice to hear from you...
I failed to mention that I changed the Nichicons to Mundorf Mlytic HV
By arnoldc
This photo was taken prior to changing the series resistor and removing the bypass cap.
By arnoldc
What causes my OD3 to extinguish?
Hello Arnold,
Please check this out.
http://datasheets.electron-tube.net/sheets/127/0/0A3.pdf
I hope that you'll find the answer on why the OD3/VR150 keeps on extinguishing.
Good Luck!
John
Hello Arnold,
Good Luck!
John
Due to real estate (and holes) issue with my chassis, I can'tput in another 0D3, unless I ditch the 5AR4.Zen Mod said:
Would you rather
a) Use SS rectification and put in 2 0D3, one for each channel
or
b) Ditch the 0D3 and just use a dropping resistor or voltage divider
Tony, I'm on the verge of doing that. While I really love the purple glow of the 0D3, I'm not that good with them.
I plan to rip this thing apart and put it in a better chassis I have or probably get one from Singapore as I'm headed that way two week from now.
In so doing, I will be able to finally make this amp fixed bias. So, in relation to that, what would you recommend for the fixed bias test points? What are they called anyway? I know it's not called RCA
wish i had the time to do those, incidentally, you have done IT, why not try one of tubelab's power drive on your 300B...wonder how it will sound like?.....
SY's favorite, IRF820 can be had for 35 pesos or about 90cents...
good luck on your singapore trip, don't forget to check out Sim Lim Square, and Burlington Square in Bugis.....hope to be there late this year or early next year for my next job...
in Newport or Oriental....raon....
stand-offs, where you can hookup aligator clips, i have some from discarded equipment.......
- Tubes / Valves
- What causes my 0D3 to extinguish?
