what are these....maybe amplifiers???
I was given about 30 of these along with a truck load of random rca parts
Does any one know what they are?
All i know so far is that they appear to be made by rca.
Perhaps small amplifiers?
There are slip on wire posts labeled
TTL
X-
F+
2
K
J
1
These are the numbers I found on them
B3
3727260-502
code B
46126
416
3747232-B2
They have a trim pot
two rca transistors (2n6387)mounted on a heat sink
two transformers (chokes?)
6 resistors
2 disk capacitors
2 orange drop caps
and a few other random parts
I have had these sitting around for a wile now and would like to do something with them!
If they are amplifiers I was thinking about building some head phone amps?
thanks for the help!
~mike~
Or some regulated power supply,
maybe a switching supply.
Transistors are NPN TO220 darlington with a hfe=2500
Could possible be of use in output stage of some amplifier circuit.
Would be a N-Channel amp.
I think you should hook up and measure what comes out of connector pins.
