What amp could I build with 600VA 2x61V AC transformers?
The LM4780 claims (in the datasheet) to take 20V to 84V, so I guess that's always an option.
So my hunch about rectifying the same pair twice in each direction makes sense? I'll have to draw it out to see it I guess..
But in conclusion, it's either much too high for any discrete amp, or slightly on the low side?
I could buy 3 and build a 6 channel (5.1 surround) lm4780 chipamp? could be interesting but I get the feeling I'm solving problems that don't exist :p
You should keep in mind that these are the absolute limits. There are additional restrictions on using the IC at a high voltage differential (Vcc-Vee). For instance you would need a larger heat sink and could only operate with 16 ohm or higher loads connected to each channel. Mains voltage fluctuations e.g. higher than average mains voltage becomes a big concern.
Hey guys,
Hypex is over stocked on some transformers, and is selling them with a steep discount. Especially this one looks very interesting to me:
http://www.hypex.nl/docs/TR700_datasheet.pdf
It's 600VA, with dual 0-61V AC secondaries at 50 euro.
I am looking to do a nice high end amp for my next project and was thinking of either a Leach or the Honey Badger, but I'd usually pay double that price for half that VA, and transformers are the most expensive part usually.
Now 120VCT is a crazy amount, are there any amps that run on -/+85V DC that I could build?
I know the LM4780 does according to the datasheet, but I'm not sure if it's a good idea, and I've already built a chip amp and would like to try out something more complex.
Alternatively they also have 120VA transformers at 20 euro, also a good price, but they'd have to be parallel for any decent setup, and rectifier bridges aren't free either.
What would you guys do?
Do you have a link to where those transformers are being sold?
84V is less than +-45V (=90V).
Read the datasheet !!!!!!!!!
