One more note: Speaker power ratings have a rather nebulous meaning. It should relate to heat dissipation for the voice coils, but sometimes is just wishfull thinking. It is usually based on "Music Power" which may mean a true average power that is as little as 1/10 the peak power. Even if the speaker is correctly rated to handle the heat dissipation, it may not sound very good at that level. In the case of a transistor amp, more is better to prevent clipping. But this is not so much a concern with tubes.
If you like edgy sounding rock, you might keep the amp power rating down to where the amp is a little overdriven at the loudness that you usually listen at! (you would have to determine what that power level is, of course)....
