Hello.
I would like to know some opinions relating to a kit i found.
Since it is in portuguese, i recommend translating the link on babelfish.altavista.com
Here it is:
http://www.neteuro.net/p/p0/fotos.php?id=3139
Many thanks!
Here it is:
Many thanks!
Is there a schematic?
Does it come with a chassis? If not, maybe this one would be better value:
http://www.worldaudiodesign.co.uk/wadproducts/kecl82_pictures.html
How it sounds will depend on the transformers and circuit topology much more than the valve.
With some feedback and good quality transformers it will sound quite reasonable, but possibly a little coloured (some like this colouration).
At this budget end, there is a big jump in performance when you go to push-pull.
The transformers have a 20Hz to 45KHz bandwidth.
No feedback, but they have this "full kathode feedback" to take care of speaker imperfections.
I'm a little confused!
What type of coloring is that you mention? 2nd type harmonics?
I really want something that would give a good listenning pleasure at bedroom levels.
So, you think that 250€ is a bit for a SE design?
Thank you once more.
