my printed Iwata 600 with bronze mount (gpa 902), white pearl.
I can print horns up to about 1,2 meter for the group. Setting up printer and technology.
very nice! much improved
Horns are a low pass filter.
Trying to find a compression driver and horn that will cover six octaves is like trying to find a unicorn.
This is the whole reason I've built a dozen Unity horns. It is the only practical solution to the problem you are trying to solve.
I don't mean this to sound harsh - believe me I wish there was a horn and compression driver that could do six octaves without breaking a sweat.
At last there is a +100 cm horn/waveguide who does six octaves and i look forward to the summer holiday at home with my JBL2451 truextent and their new huge friends
[/url]
[/IMG]
Few more pics.
Is there any plans for this guy and all the build info and parts needed? Sorry if I mist it in a early post
6x6cm throat but this pair has slightly larger. Idea is to use 4-6" midrange, optionally 12" OB woofer in pedestal. If customer wants I print comp driver adapter.
I wish I could understand your plans. Lol
These horns look great
Hello jzagaja, I do have a AMP25120 and I'm planning to build a center channel with it. Is it possible to order the one horn for it ? Thank you, Alex300Hz horn for AMT 25120 finally arrived.
I didn't think these were still available.Hello jzagaja, I do have a AMP25120 and I'm planning to build a center channel with it. Is it possible to order the one horn for it ? Thank you, Alex
OK. I only mentioned because I'd looked at the horns-diy site recently and couldn't see them. If available I'd like some to see how they compare to the TPL150Hs I have.Thanks Brett....actually I looked more carefully and it is way too big for my application.
Alex
- Group Buys
- Waveguides and horns
