Hi there
I would be interested in a parts list or bom for a 100w aleph X . I have a set of Kari's boards (excellent boards I must add) . I just thought someone might have done some of the hard work already, then I can spend more time making a chassis Thanks in advance....
dave
dave
Also this guy, made a BOM for a 100 watt's. Monoblocks, right?
Lots of usefull info on Thomas Chaos page.
Steen
http://www.penguinlovers.net/audio/
BTW. 100 watt's A-X's spells serious heatsinking!
Steen
If you have Kari's boards, I think they are meant for something like 70 watt's. Grey's original used 4 fet's per channel. Kari's (KK's) uses 8. I think to get 100 watt's you are looking at 12 fet's per channel! You need the outputboards of Kari's or to hardwire them, as I did.Assears, I thought the parts on the board are for Greys original Aleph X which is 45w or somthing close , not 100W...?
Steen
BTW. these four heatsinks is for one channel
Go figure! I think the source resistor value on KK's and Karis boards is a bit on the low side! I wouldnt be confident running that amount of Amperes through only 4x2 FET's. I prefer 4x3 FET's. But this is just a gut feelingNo Kari boards about 100W, 5 to 6A bias I think.
Steen.
Assesears, have you built yours yet ?
No not yet, I built a krell ksa50 klone can't find the pic here though, and it turned out could not get more than 100W dissipation out of them the sink temp was too high for long time reliability. Just finished a mini aleph last week and it sounds magical, real happy with it. Need some money to buy some huge sinks for the 'X' because these alephs are well worth it.
cheers
Pass DIY Addict
Joined 2000
Here is the list I've been using to plan my amps. Its an excell spreadsheet that includes William's power/heatsinking calculations, William's 100w parts list, and Greys original parst list for 37w. These are materials that have all appeared here before, but I've put them into a single file, and made small updates as the project has progressed.
All of the part numbers and corresponding prices are included.
dhole,
The Karu Aleph X boards are 100 watt versions and the schematic is based on the 100 watt Aleph X found on Kristijan's web site.
http://web.vip.hr/pcb-design.vip/alephx.html
If you look back at the origional Kari Aleph X Wiki ( http://www.diyaudio.com/wiki/index.php?page=AX ) he admits it is based on Kristijan's schematic.
Cut from the wiki:
The layout is based on KK's schematics and they can be found here:
Pictures of the layout can be found here:
http://w1.859.telia.com/~u85937463/alephx.png
http://w1.859.telia.com/~u85937463/driver.png
Cut from the wiki:
kilowattski
Thanks for the reply. i bought Kari's boards just in the nick of time and hadnt followed the thread. They have all the component values on them which is nice too. Do you have any comments on my heatsinks ? I dont have any ratings for them as I picked them up cheap from a salvage plant.
dave
dave
Assesears
The list states that r1-r3 on the utput board is 0.39 but the part lists in RS as 39R . Which is correct ? Do you have the original parts list as the boards dont show the values of thoses resistors. Also the r4-r6 on the boards are 208 and you have selected 221 is that just the best match ?
regards
dave
regards
dave
From what i heard KK's recommending 0,11K/W sinks per channel. I'm about to complete mine as we speak, i have some metal work left to do (copper plates for the caps). I'm going to use a 800VA 2*15V trafo for mine as i need more power to 4 ohms than 8. At this point i'm going to use 8 fets per/chan and if more power is needed i can easily add 4 more per/chan, needs a adjustment on the ccs tho. Power supply will be a CC-R-CC (89000uF + 89000uF + 0.47ohm + 89000uF + 89000uF) per side so double that for +/-.
/Kari
/Kari
- wanted :100W Aleph X (kari's board) bom/parts list
