W5-1611 SAF - The Sequel
I see a few folks have tried different designs for the W5-1611SAF, so going to try my luck.
Since I typically dance to the beat of a different drum here is the direction I'm headed.
I had a few ideas but was inspired by plans found here (post 13):
http://www.diyaudio.com/forums/full-range/188620-onken-near-field-monitor-2.html
AND other full range boxes with a W shape & flare ports. This will be a combination of both (similar to red box). The tuning will be done on the work bench by trimming the flare ports. Not easy to see in pic. but glued 4 pieces of 5" x 1/2" poplar that will be cut/fit/sanded and again, trimmed as needed.
Cones are coated - thin layer of RTV 118.
Speaker Driver: http://www.tb-speaker.com/detail/0624_11/w5-1611saf.htm
Fs is 20hz off? I'll check that here.
Jeff, went back to WinIsd, found out could not work vent sizes in inches - used mm and then had to trick the widow and start high and work my way down. [kept losing the response line]
Here's what I can up with two (2) vent/ports (L&R).
4 wood strips = 52mm, 13mm each.
John, glad you are still here.
The silicon:
(1) Only use RTV112 or RTV118; they are self leveling products
(2) it will give you more bass - easy trick to lower the response
(3) the speaker guru that we used to work with, said it took the ringing out
(4) I think it makes a plastic cone sound more natural
(5) it is easy to take off if you don't like it
Yes, a couple of annoying glitches.
I took grindstone's numbers and ran another sim using your vent sizes. Box is 18.5L @57Hz tuning. You'll notice the vent length is quite a bit less, due to the higher tuning.
jeff
I had planed on finishing these this weekend, no such luck.
Might have them together in week or so. However, so far so good, I like the proportion.
Top is not glued - only glue one "side" at a time (I don't like glue running all over).
Picking up speed
Picking up speed, but only have a few hours into this so far. Going to tune it up today.
The white screen is a blocker to keep the damping material from blocking the ports; found it in our last pizza box order. I may have to go order another pizza for the second one.
Will probably just throw the pizza out and keep the white screen - the pizza was terrible :xeye:
Gaskets
I'd much rather pay an extra dollar for factory gaskets, vs. making them. One resin not to buy less expensive speakers, have to spend more $$ fixing them.
Might put some hard wood on L&R panels (for looks).
So far so good.:)
