Has ayone played around with them yet? I cant find a thing on the net about them. They're being sold at parts express.
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=264-846
They look to be almost a drop in replayment for fe103e and fe108ez horns. With very little modification.
Chris
Chris
Corloc said:Yah, the Tang Bands have a little more spl, but seem a little ruffer at the top end than the CSS fr125's do. A bonus is the TB's are $35 cheaper than the fr125's. I have ordered the TB's today and will recieve them sometime tomarrow.
GOOD LUCK!
those look like awfully fun lil drivers...
Mine are going into a 9.25 x 6.25 x 7.25 dp 3/4" MDF 2.5 liter cabinet. Going virtually against the wall and the bass alignment looks better for this than FR-125.
I have an e-mail to Allen at T-B about vented vs. sealed. They look like they are to be vented but so close to the wall - what's the difference?
Also with the 8dB peak at 15-20kHz they apepar to be in break-up mode. Anyhow much better Qms than Fostex so I hope they won't have that bright edge Fostex are known for.
I ran my finger around the bamboo driver paper and I must say it is the most DEAD sound I have ever heard - a very good sign I think. I like the small Neo motor which allows better air flow behind the driver. Also cast frame is very nice.
Hopefully they will be forgiving enough and match well with "T" amp - my next project when time allows.
chuck55
"Also with the 8dB peak at 15-20kHz they apepar to be in break-up mode. Anyhow much better Qms than Fostex so I hope they won't have that bright edge Fostex are known for."
Well they are nowhere near as bright as my FE206e's. I listen to mine between on axis to 10 deg. toe in. I haven't listen to any other of Foxtex driver to compair.
All a can say is that the W4-1320 is smooth, and only once and a whlile have a bright egde. Could be that bump in that range.
The 1320sb's are out of the OB's and in old shop cab that were designed for the W4-616. I think 4L 1.5" x 5" port? Not perfect, but 90% of the time you can't pick the drivers position out of the sound field.
Mine will be going into Modded Bouchhorn MKII
Chris
Chris
OK just got mine in the mail yesterday.
Got someone thats going to test them for me so when he is done I will link the Praxis and Klippel reports.
Frequency response and off-axis response
Actual Thiele Small parameters
non-linear distortion analysis
waterfall and/or energy storage analysis
BL/KMS curves
BL/KMS curves
T-B recommends:
"intended for thin or flat speaker box design"
Here is a 3.5 liter cabinet design from Aan at T-B:
c:\...\w4-1320sb vented box design.pdf
Unfortunately, I can't seem to copy the .pdf file Alan e-mailed me. Here is the best I can do:
File: w4-1320sb.bb6
w4-1320sb vented box design By Eagle Chang, TB-speaker
Ningbo China
+86-574-86553648
+86-574-86551617
Box Properties
--Description--
Name:
Type: Vented Box
Shape: Prism, square
--Box Parameters--
Vb = 3.558 liters
V(total) = 4 liters
Fb = 80 Hz
QL = 7
F3 = 97 Hz
Fill = normal
--Vents--
No. of Vents = 1
Vent shape = round
Vent ends = one flush
Dv = 38 mm
Lv = 111.9 mm
Driver Properties
--Description--
Name:
Type: Standard one-way driver
--Configuration--
No. of Drivers = 1
--Mechanical Parameters--
Fs = 75 Hz
Qms = 1.5
Vas = 5.985 liters
Cms = 1.297 mm/N
Mms = 3.472 g
Rms = 1.091 kg/s
Xmax = 3 mm
Xmech = 4.5 mm
P-Dia = 85.19 mm
Sd = 57 sq.cm
P-Vd = 0.0171 liters
--Electrical Parameters--
Qes = 0.484
Re = 6.8 ohms
Le = 0.01 mH
Z = 8 ohms
BL = 4.794 Tm
Pe = 20 watts
--Electromech. Parameters--
Qts = 0.366
no = 0.503 %
1-W SPL = 89.16 dB
2.83-V SPL = 89.87 dB
Normalized Amplitude Response (dB-SPL/Hz) BassBox 6 Pro
dB
6
0
-6
-12
-18
-24
-30
-36
5 Hz 10 50 100 500 1 K 5 K 10 K 20 K
Custom Amplitude Response (dB-SPL/Hz at 1 m) with 20 watts BassBox 6 Pro
dB
109
103
97
91
85
79
73
67
Maximum Acoustic Power (dB-SPL/Hz at 1 m) BassBox 6 Pro
dB
108
102
96
90
84
78
72
66
File: w4-1320sb.bb6
Ningbo China
+86-574-86553648
+86-574-86551617
Box Properties
--Description--
Name:
Type: Vented Box
--Box Parameters--
Vb = 3.558 liters
V(total) = 4 liters
Fb = 80 Hz
QL = 7
F3 = 97 Hz
Fill = normal
--Vents--
No. of Vents = 1
Vent shape = round
Dv = 38 mm
Lv = 111.9 mm
Driver Properties
--Description--
Name:
--Configuration--
No. of Drivers = 1
Fs = 75 Hz
Qms = 1.5
Vas = 5.985 liters
Cms = 1.297 mm/N
Mms = 3.472 g
Rms = 1.091 kg/s
Xmax = 3 mm
Xmech = 4.5 mm
P-Dia = 85.19 mm
Sd = 57 sq.cm
Qes = 0.484
Re = 6.8 ohms
Le = 0.01 mH
Z = 8 ohms
BL = 4.794 Tm
Pe = 20 watts
Qts = 0.366
no = 0.503 %
1-W SPL = 89.16 dB
dB
6
0
-6
-12
-18
-24
-30
-36
dB
109
103
97
91
85
79
73
67
dB
108
102
96
90
84
78
72
66
anymore work on these designs?
Hi Guys,
I am going to bring back a pair of these from the States and I would like to build a simple design that could either pair with a sub or stand alone at fairly loud volume. Have you reached a design that you are satisfied with? If so, could you please share particulars?
Thanks.
Hi Guys,
Thanks.
Bamboo...
http://www.zillaspeak.com/Bamboo.asp
I have been enjoying mine. I stained the boxes last night and applied the first coat of poly...
I like their sound alot. But they sound better in the much larger pipe so i feel a different box can maximize performance.
Peace,
Godzilla
Peace,
Godzilla
- Full Range
- W4-1320sb
