Voltage gain stage for Non-NFB MOSFET current amp
That's a matter of perspective. A large percentage of music lives below 2 kHz, just where your plot starts to fall apart. Very fine at high frequency, yet the the deterioration of performance with decreasing frequency is very poor.
I guess it depends on how one defines "poor." From the perspective of a bean counter, I suppose one could say that it is rather "poor." But from a more practical and meaningful perspective, i.e. actually listening to the result, the experience belies the "numbers."
I've always figured that a constant level of distortion against frequency contributes to good overall sound quality of a system, however I may be wrong.
Well, grab yourself a pair of 10C's and find out for yourself.
(Perhaps somone should invent a transformer with built in negative feedback :spin: )
Or you could drive it from a negative impedance equal to the primary's winding resistance. That'll keep the bean counter's happy.
se
Aren't we more tolerant of distortions in the bass region than in the upper frequencies?
Generally what we're more tolerant of is low order distortion versus high order distortion. With transformers, their distortion is pretty much just third harmonic.
Also, transformers exhibit nowhere near the amount of IM distortion that one would typically get from an active circuit with similar levels of THD.
Their distortion characteristics are rather unique and more benign than the raw numbers would lead you to believe.
se
ra7
Joined 2009
Yes, I agree with your conclusion about lower order distortion.
I have read at several places, although I have no references at the moment, that the human ear is not able to distinguish distortion in the nether regions easily. Conventional cone speakers start distorting much earlier in the bass frequencies before distorting higher up. A harsh treble is much more annoying that a "harsh" bass, and I haven't ever heard a harsh bass.
ra7
Joined 2009
btw, since you already have the jfet boz, just hook it up to your power stage and you should have enough gain. Check out the thread though, they have suggestions somewhere in there about directly connecting it to the F4, might be of help to you.
I don't think it's correct for this application, i believe it starts to seriously distort past 2v output after looking that the graphs in that thread.
Gripracer,
You asked how much gain is enough. The voltage amplifier should remain linear, while being capable of driving the "finals" into clipping. The FET PSU starts with 18 VRMS. The I/P is 2 VRMS. A voltage gain of 10 should prove adequate.
You asked about using a 6Н2П (6n2p) or 6Н6П (6n6p). For all practical purposes, the 6Н2П is equivalent to the 12AX7. That type has an amplification factor (μ) of 100. That's way too big. OTOH, the 6Н6П data sheet indicates that it is quite suitable. A quick glance suggests a 160 VDC plate to cathode differential and -6 V. as the grid bias.
How 'bout one with no feedback, highly linear, ultra low noise, outstanding common-mode rejection, can accept balanced and unbalanced sources, and has infinite PSRR?
I once made an amplifier using a step up audio transformer as the VAS. It worked OK but lacked a certain "definition". I gave up on the idea because I was searching for something much better. It just seemed too simple. There must be a reason why everyone is not doing it.:rolleyes:
But for certain, the quest is entirely possible using only solid state.(no transfo of course:p) As for relative simplicity?....to be a realist, unfortunately :no:
There is requirement for multiple stages and multiple layers of feedback.:eek::spin:
That's rather like saying you once made an amplifier using transistors as the VAS and you didn't like it so you gave up on transistors (or tubes as the case may be).
Just as it's possible to create a solid state or tube amp that doesn't sound good, it's just as possible to use a transformer as a VAS that doesn't sound good.
And without knowing exactly what transformer you used and under what conditions it was used, it's impossible to say why it may not have sounded so good. For all I know, you might have used a $6 Edcor transformer or something.
Well, given that some of the finest recordings ever made involved using transformers for voltage gain, I don't suspect it has anything inherently to do with transformers in and of themselves.
se
GK
Disabled Account
Joined 2006
So 20kHz don't matter then?
In this case, those transformer distortion plots really don't mean a thing. With the highly variable and non-linear input impedance (both with ampitude and frequency) of that MOSFET power output stage, using transformer as a VAS, driven with anything but an ultra low impedance source, is a recipe for a monumental distortion generator.
I'm happy that I've finally contributed a thread that people are discussing in.
However, I think I am sold on a 6N6P stage. It is the best and most simple choice for my conditions. I imagine the completed amplifier will sound really amazing with so few complications!
Point taken.
I thought I'd mentioned it here, but it turns out it was in a reply to a visitor message, that the circuit you hitch it to should be able to perform well when fed from the transformer's relatively high output impedance.
So if the MOSFETs in his power buffer will perform that bad as a consequence, perhaps put a B1 in between the two.
se
