The world smallest (?) tube buffered inverting t-network gainclone design by Franz G,develop by Franz and Zang(digi01).
for the first round,the pcb board is available.the price is $20 EURO per kit including shipping to anywhere.
the kit will include:
1 power supply board,
1 inverting t-network lm3875 board,
1 tube buffer board,
1 assembly instruction.
Zang
Zang
to earsandeyes,
yes,the pcb set is sufficient for a stereo amp.I will start a components GB at round 2.Franz is working on the enclosures now.
to dave,
yes,the set is available without the power supply board,asking for 12 euro to anywhere.
p.s.
I will accept order from today till october 20.the board will arrived buyer around october 30.
WIKI
Zang
to dave,
p.s.
WIKI
Zang
I will publish the complete schematics by next weekend.
For those, who order just the amps boards: dont forget to implement some 20 to 30 second switch on delay for the powerstage.
While the tube is warming up, you will get full dc output during some seconds, without implementing a delay!
Franz
Franz
I am in delay with the documentation.
Reason: last weekend, I finished a PCM2706 USB DAC and played with it. And yesterday evening, I got fascinated by the idea, to build a RIAA pre with OPA2227 and designed immediately a pcb.
I hope, to finish the promised docu by beginning of the next week and offer at this time a mini-enclosure.
Franz
Franz
First step: the partslist (available as Excel-sheet, see zip-file).
Mini Tube buffered GC
PSU enclosure
Amp enclosure
Chinch connectors 2
Speaker-Connections 4
230V Connector incl. Filter and switch 1
Volume Knob 1
Heathsinks 1
Tube socket noval 17.5mm dia 1
Screws etc. 1
Wires, Cables, shrink tubes 1
Torroidal 2x25V 225VA 1
Trafo 2x18V 1.5VA 2
Trafo 6V 2VA 1
PSU
PCB 1
9 pin D-sub (female) 1
Fuseholder 1
Relais 6V 1
Dioden 60V/6A MUR860 8
Dioden 100V/1A IXYS 1-16D 2
Rectifier 10V/400mA 1
NE555 1
LM317 1
LED blue 1
10000uF / 35V 2
1000uF / 35V low ESR 2
1000uF / 63V opt. 100V (low ESR) 2
470uF / 63V opt 100V (low ESR) 2
4700uF / 16V 1
47uF / 16V 1
10uF / 16V 1
1uF / 63V 3
1uF / 63V opt 100V 2
0.1uF / 63V 3
0.1uF / 63V (opt, Diode bypass) 8
200K Trimmer liegend 1
4.7K Spindeltrimmer (oben) 1
33K 2W 4
100R 2W 2
1R 0.4W 2
200R 0.4W 1% 1
3.3K 2W 1
100K 0.4W 1
Amplifier
Main PCB 1
Tube PCB 1
E88CC 1
LM3875TF 2
50K log Poti stereo 1
330uF / 35V low ESR 4
10K 2W 2
180R 0.4W 1% 2
3.3K 0.4W 2
18K 0.4W 1% 6
47K 0.4W 1% 2
0.1uF MKP 60V 4
Franz
PSU enclosure
Amp enclosure
Chinch connectors 2
Volume Knob 1
Heathsinks 1
Screws etc. 1
Trafo 2x18V 1.5VA 2
Trafo 6V 2VA 1
PSU
PCB 1
Fuseholder 1
Relais 6V 1
NE555 1
LM317 1
LED blue 1
10000uF / 35V 2
4700uF / 16V 1
47uF / 16V 1
10uF / 16V 1
1uF / 63V 3
0.1uF / 63V 3
33K 2W 4
100R 2W 2
1R 0.4W 2
200R 0.4W 1% 1
3.3K 2W 1
100K 0.4W 1
Amplifier
Main PCB 1
Tube PCB 1
E88CC 1
LM3875TF 2
10K 2W 2
180R 0.4W 1% 2
3.3K 0.4W 2
18K 0.4W 1% 6
47K 0.4W 1% 2
0.1uF MKP 60V 4
Franz
I just added an updated excel sheet, containing the parts-numbering like the psu-pcb.
The parts for the amps board are not numbered, but printed by their value on the boards.
Digi: did you draw any schematics in the meantime? We never had a schematic from the psu, we just worked with the print
Franz
Franz
That's a ECC88 on your photo Hanzwillem, They have no gold pins and the microphone qualitys are not that good as the E88CC (i read that from internet).
Thats why i alsked for the quality off possible substitutes.
Is the ECC88 in your opinion as good as the E88CC? If so, i use a ECC88 as well (i am a relative nooby with tubes).
- Group Buys
- VBITNGC group buy
